Results 1 to 9 of 9
Thread: Lack of bandsaw, is there anyway around this problem?
    new york city burbs
    10,188
    I need to cut 12 rear legs for chairs.
    I havent measured the exact degree of slant that the legs will slant backwards above the seat area, but Im limited because of no bandsaw.
    I have wood that measures 2.75 inch (almost 12/4)thick by 6 inches wide, lengths vary from 4-8 feet.
    If I had a bandsaw, I could slice the wood to 1.75 inches thick. I dont.
    I can plane, but then I have to sacrifice 1 inch of wood. Mahogany is expensive.
    I can slice it on my tablesaw, but that limits me to cutting it 3 and 3/8 wide, which means it will cut down on the angle of the back.
    Do I have any options? I thought about cutting wood half through, like dado cut, then flipping over on table saw, and plane even if I need.
    Too dangerous?
    with the angle on the upper back of leg, Id prefer around 3.75-4 inches on the face of lumber, so I can cut it out. If I limit the face width of lumber, I limit the slant.
    Does this make sense?
    Sacramento, CA
    1,367
    You can absolutely resaw with your table saw. I would suggest not going all the way through with the 2nd cut, though. Go about 1/16" or so shy and then "snap" it free and smooth the surfaces. This way you're not dealing with a narrow or top-heavy offcut that could easily land on the top of the blade before your splitter/riving knife can stop it.
    Jason Beam
    Sacramento, CA
    Dec 2008
    falcon heights, minnesota
    5,610
    when i first worked up the plans for my chairs, they originally had leaning backs. i figured i could do the outside angles with no problem, but it was the inside angle that gave me sufficient trouble that i went with straight legs. for me, if i were to do it over again, i would have a template of the leg, cut the outside angle on the table saw, the inside on the band saw, or jigsaw in allen's case, then route the edges to the template.
    benedictione omnes bene
    www.burroviejowoodworking.com
    I suggest you buy a Freud Thin Kerf saw blade. A bit on the expensive side, but they cut like a hot knife through butter and the cut is very clean. The ripping blade is around $40 and the crosscutting blade is about $60. But really worth the money.
    DKT
    new york city burbs
    10,188
    Freud blades are all I own now.
    I have one new Avanti ripping blade still in package, so maybe Ill give it some work.
    Speaking of Freud blades, when is amazon going to run the buy 3 get 15% off again?
    Topeka KS
    118
    use your table saw to cut about 1/4 way through on each side and then use a hand saw to cut the boards the rest of the way
    Als ik kan
    Allen, I've done it, cutting from both sides. Just to it carefully and cautiously. I used featherboards (before the blade only...not after), splitters and pushing devices to make sure I stayed plenty far from the blade, and made doubly sure I was out of the line of fire in the event of a kickback. I had to problems with it. Just be on your toes.
    new york city burbs
    10,188
    I fell in love today with a 14 inch bandsaw, powermatic, maybe Ill wait till next week or so to cut up that thick stock.
    17,475
    in love
    hey allen yu need a second cousin,,yu fall in love with another tool so soon whats that part of the world coming too???
  1. Bandsaw Dust Collection Problem Solved
    By glenn bradley in forum Off Topic Discussion
    Last Post: 09-17-2011, 08:36 PM
  2. Lack of turning weekend
    Last Post: 03-15-2009, 05:38 PM
  3. Bandsaw tension problem
    By Westley Rosenbaum in forum General Woodworking Q&A
    Last Post: 12-08-2008, 02:59 PM
  4. Bandsaw problem - Need assistance
    By Lee Laird in forum New Tools
    Last Post: 06-30-2008, 03:02 PM
  5. Problem With My New Bandsaw....
    By Corey Hallagan in forum New Tools
    Last Post: 10-30-2007, 02:47 PM
