Page 13 of 235 FirstFirst ... 3910111213141516172363113 ... LastLast
Results 121 to 130 of 2343
Thread: Organ build
  1. #121
    3,898
    I wish I had enough talent to even consider building something like this, looks like fantastic stuff, thankyou again Jay for showing us your work.
    Allen I am going to post soon how to build a single pipe so if you want you can try your hand at it. If you can build it an make it play (which I'm sure you can with our help) you can build a organ.
  2. #122
    3,898
    Quote Originally Posted by Charlie Schultz View Post
    Jay,
    I ordered from Peter at RollCutter. I sent him an e-mail about it, but no answer yet.
    If possible, a photo of the bellows/reservoir would be appreciated, thanks.
    Charlie here is what it all looks like without the bellows cloth installed hope it helps
Name:	Bellows 1 small.jpg
    spacer between the bellows
Name:	Bellow open 1 small.jpg
ID:	30291Click image for larger version.
Name:	Bellow open 2 small.jpg
    Bellows open
    res on top of bellows
    res open
ID:	30295Click image for larger version.
Name:	bellow res join.jpg
    bellows cloth used to join and seal bellow together then res is screwed to top of bellow with a seal around the edge to make air tight. ( I have a lot of seal for those that need it)
  3. #123
    Oct 2008
    1,239
    Quote Originally Posted by Jay Caughron View Post
    Toni add Dean to your list as he has already started his build and has a blog started so we can all keep up with him. I'm still working on Royall
    Jay
    OK, OK, Jay PM the cost and the how to's and I'll at least get the plans coming Geez twist any harder and I won't be able to build anything!
    Maybe I should sell the popcorn to the spectators to off set the build!
    Aloha,
  4. #124
    3,898
    Quote Originally Posted by Royall Clark View Post
    I knew we would get you sooner or later.
    Here is Johns email address best just to ask him with you time differences you should have a answer when you get up as he check for orders in the a.m. and he is 6 hr ahead of me and I think you are 4 hr behind me. Do you have Skype?
    Depending on when you go to bed you may have a answer tonight yet.
    rsmithbusker"AT"ntlworld.com replace the "AT" with @
    Welcome aboard Royall
    Jay
    Last edited by Jay Caughron; 04-06-2009 at 03:15 AM. Reason: update email address for plans
  5. #125
    3,898
    OK here goes with the Pipe build I hope everyone can figure it out if not speak up and I will try to do a better job of explaining. Going to try to give enough info so everyone reading this can build this pipe and make it play after that you will need to buy the plans from John Smith.
    Pipe width is easiest to cut using mm if you want it to be in inch's just divide by 25.4 (Pipe is 8 percent bigger then finished pipe to allow for trimming)
    Cut out the pipe pieces out of 1/8" stock 2-14mm x 6 7/8 (top and back) and 2-23.5mm x 6 7/8 (sides) The inside measurement should be 14mm x 17.5mm so you will have to adjust the sides for the thickness of stock you are using.
    This shows marking where the mouth goes mark it up so the top of mouth is 3/4" from end of pipe. Mark all three part at the same time (2 sides and back)
ID:	30300Click image for larger version.
ID:	30301Click image for larger version.
    This shows how I glue them up on the jig ( I'm showing 2 pipes here) this is the side (on bottom) and the top (on edge) just put glue on the edge and push down with the clamps and use something square to line them up, the glue will set enough to hold in less than 5 min so you can move along pretty fast.
    This shows the top after cutting off the end cap and the mouth insert (cut just a little long as you will sand them down later), that leaves the right length for the front opening without cap. Use the part you have glued to get the length of the 2 small parts as shown on the top of picture on the other pipe. (hope thats clear)
ID:	30304Click image for larger version.
ID:	30305Click image for larger version.
ID:	30306Click image for larger version.
    This shows sanding an edge on the top just make it a pretty flat angle and the edge of mouth piece about 45 or so.
    continue on next post.
  6. #126
    3,898
ID:	30309Click image for larger version.
ID:	30310Click image for larger version.
ID:	30312Click image for larger version.
    This shows gluing up the bottom & mouth, Make sure its sq and then glue the other side on and clamp make sure your joints are sq and tight.
ID:	30313Click image for larger version.
ID:	30314Click image for larger version.
    Now glue the top in as shown aliening with the top of pipe and clamp
    After sanding the top flat you should have a flat spot on this edge that needs to be at lest 1mm (1/16") wide. If not sand as picture below with a small sanding stick
ID:	30317Click image for larger version.
    Next post
  7. #127
    Oct 2008
    1,239
    Jay
    I sent the email off. If I read correctly earlier in the tread John is in England? When I sent the mail it was 6:30 PM Friday and 4:30 AM Saturday morning in Jolly Old England. I don't have Skype, but I have Magic Jack. Same thing I guess. I didn't give him the phone number as it would be difficult to explain tot the wife at this time if she took the call. Better to say sorry later than argue about it now
    Aloha,
  8. #128
    3,898
    Glue a 1/4" block 1 1/2" long to back of pipe and drill a hole from the other side to match the tubing you will use, this one is 5/16" shoot for a snug fit
    Cut a shim from a pop carton or what ever as shown. It must be .5mm (or less NOT more) thick and I know that pop cartons are the right thickness just lightly sand the paint off as shown this is a critical measurement. Glue to pipe.
    Now cut a bottom cap 1mm longer than needed and glue to bottom set it just above the mouth about 1mm not critical (just make sure its a little above the mouth) Then cut a top as seen under my thumb (about 1 1/2" long or what ever length you want and cut and sand a 45 deg edge on it.
    Also make a plug as shown and cut a piece of chamois as shown plug is just smaller than top opening of pipe sand to size as needed.
ID:	30330Click image for larger version.
ID:	30331Click image for larger version.
    Put a dab of glue on plug and glue to chamois, install into end of pipe. This needs to be a snug fit you want no leak here but you also need to move it up or down to get on note. Check pipe for leaks by blowing on bottom if you have any leaks they will need to be sealed to make pipe play right. Sealing the pipe is the most important it can not have any leakage. I use shellac to seal the inside of the pipes
    Use a rubber band to attach the top cap so you can move it up and down while blowing in the hole in back to voice the pipe. This is something that you might want to watch the video by Phil Radford that I posted a few posts back. I couldn't find it ether so here it is
    Last picture is of the tinner when its on note you do that by sliding the plug up or down. I was getting tired when I done this as it should be set at D# not D and I was running out of breath.
    If you have any questions just ask once you are done building this pipe you are well on your way to building an organ.
    Enjoy
    go to post #156
  9. #129
    3,898
    Royall he will more than likely just send email not sure as to how early he gets up but I do know that he check his email in the a.m.
    I also told him I was trying to get a guy from Hawaii to join us so he knew you were coming
    Jay
  10. #130
    Oct 2008
    1,239
    Jay
    Hmmmmmm what did you say your commission is???
    Aloha,
Tags for this Thread
