Page 51 of 267 FirstFirst ... 4147484950515253545561101151 ... LastLast
Results 501 to 510 of 2668
Thread: Organ build
  1. #501
    Jay,
    I would be very interested in US punched JS 20er rolls, $80+ US is pretty steep for 4 minutes of music from the U.K., that's more that an 'O' roll!
    Any details about prices, and songs?
    Ira,
    Cool tracker bar!
  2. #502
    4,563
    Quote Originally Posted by Gary Davis View Post
    Jay,
    Ira,
    Cool tracker bar!
    Gary so far I have 2 people wanting to know about rolls. I am waiting for the list of music from the guy but I know he is busy right now. He wants at lest 8 to 10 people to comment before he rebuilds his punch which with the cost involved I think that is only fair.
    Will keep everyone informed as I find info but would like to hear from more people who will want rolls.
    Jay
  3. #503
    Independence, Kentucky
    1,359
    Organ build
    Jay I am getting ready to make the crank shaft and noticed that you used aluminum for the connecting rods? Or am I mistaken? I would like to get a better idea of how you made your connecting rods if you don't mind.
    Charles
  4. #504
    Aug 2009
    Salt Lake City, UT
    35
    A quick update of the progress from this weekend. I don't have pictures of most items taken, but will do so tomorrow. I got the take-up spool manufactured, the lid lock down, and all the interlocking wheels done. The tracker bar is now mounted up as well. I think that at this point I am ready to start hooking up pipes!
    One interesting change I made to the drawings John provides is with the idler wheel clutch. I designed a slightly different way to do this that I like better. See the pictures below.
    The pictures were taken before the hole for the idler shaft was drilled in the middle solid block (made out of 2 layers of 3/4" baltic birch ply laminated together).
    When the "Switch" is straight up the idler wheel is engaged, when the switch is pulled to the side the wheel is disengaged. It works pretty well but if I were to build it again, I would make it so that there was about 1mm more difference in the height of the idler shaft between the two states.
    Attached Thumbnails Attached Thumbnails Mobile Photo Oct 10, 2009 18 45 05.jpg   Mobile Photo Oct 10, 2009 18 45 30.jpg
  5. #505
    4,563
    Quote Originally Posted by Charles Hans View Post
    Charles
    Charles not sure why I missed this post but I will try to get some pictures of the crankshaft and how I built it up I can tell you it is 5/16" X 3/4" alum and easy to make ya need a good drill press tho.
    Off to the shop
    Jay
  6. #506
    1,359
    Organ build
    Thanks Jay. I have some aluminum and a drill press,
    so I am good there, and tapping holes is no problem.
    Charles
  7. #507
    4,563
    Well Charles I didn't get it done as I wanted but here are some close up pictures and maybe this will help you get going.
    This is just to show the top edge drill the hole to fit the screw head first then drill the hole to tap and tap the hole all the way through do this before cutting the slot so its a solid piece after tapping cut the slot and the drill the head side so the screw goes through without interference.
    These are just some more picture to see the other sides.Click image for larger version.
ID:	38121 Click image for larger version.
    Now if anyone wants I will make up a bunch of these as when I bought the alum I could only find it in an 8' length so I have plenty I can cut you blanks or make the block complete your chose
    I have this set up in 2 organs and it works great with out a hitch.
    Jay
  8. #508
    May 2009
    Poway, CA, near San Diego
    174
    Hi folks,
    Here is a picture where you can see my crankshaft. I made the throws from steel. (because I had it) I glued it together with loctite (not sure of the number, the red permanent kind) Then I drilled through each joint and drove in a dowel pin. Did the same on the 26 note. Still working fine.
    By the way, there was an organ rally in Sutter Creek, CA last weekend.
    I was there, and a buddy of mine that has built a busker and senior.
    Check this out:
    Huge new Raffin 31/100 (Not homemade):
    http://www.youtube.com/watch?v=TIB7eSfiocQ
    Wurlitzer 103:
    http://www.youtube.com/watch?v=QB5wtf6yNBY
    Me:
    http://www.youtube.com/watch?v=lZWzjlofrIA
    Large Bruder (From last year):
    http://www.youtube.com/watch?v=6V0wrr0bodU
    Plus a few stills:
    http://www.flickr.com/photos/unfortunate_bystander/sets/72157622572727426
    Good luck,
    Bob
  9. #509
    4,563
    Nice stuff Bob Thanks for post this. Your 26 sounds great but you are like me I just cant seem to find the time to finish up the case been having to much fun playing it and now John has me talked into building a Topsy (so may pipes so little time)
    Jay
  10. #510
    You organ builders remind me of the Irish song "Oh Danny boy, the pipes, the pipes are calling.."
  1. New Organ Build Topsy 3
    By Jay Caughron in forum Flatwork Project Showcase
    Last Post: 12-17-2017, 03:48 PM
  2. Tom's 31 note organ build
    Last Post: 12-11-2017, 05:41 AM
  3. Too Good To Hide In The Organ Build Forum
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 05-24-2013, 02:02 PM
  4. Re:Organ Build Thread Started by Carol Reed
    Last Post: 11-11-2012, 01:36 PM
  5. The FWW group build Organ
    By Jay Caughron in forum General Woodworking Q&A
    Last Post: 04-26-2010, 01:33 AM
Tags for this Thread
