Results 1 to 8 of 8
Thread: Glue?
    Aug 2008
    Reno, Nv
    3,632
    Glue?
    So I'm gluing up this blank of maple and walnut and wondering if CA is cool to mix with yellow (Elmers wood glue) Any thoughts?
    Central Illinois
    936
    My first question is WHY?
    If you are gluing wood to wood Yellow glue is fine all by itself.
    I believe that the combination wouldn't work, but you can always try it on a couple pieces of scrap.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    I'll echo Bruce. I'd use just yellow glue, and I suspect mixing them would be worse than either of them separately. If I recall the details correctly, the yellow glue cures by loss of moisture, and the CA cures by loss of oxygen. Seems if they were mixed, they could get in each other's way.
    I could be completely off base, so like Bruce said, you could always try it on a couple pieces of scrap.
    Goodland, Kansas
    4,834
    I wouldn't mix them Jim. I think you wouldn't gain a thing. I agree with Vaughn. I am not so sure that the yellow glue wouldn't act as a accelerator for the CA.
    Bernie W.
    Tellico Plains, Tennessee
    4,353
    I concur with all above... don't think it would work, nor would you gain any strength or advantage. I use CA if gluing up pen blanks, but for pepper mills or bowls I use a wood glue.
    Chuck
    Tellico Plains, TN
    Aug 2008
    Reno, Nv
    3,632
    That answers that one . I do glue-ups on most of my bottle stoppers. Since they do end up in the fridge sometimes, I was thinking the humidity would breakdown the yellow glue, as stated on the label
    Goodland, Kansas
    4,834
    Jim I use Titebond III waterproof. I have glued up quite a few and never had one come apart.
    Bernie W.
    11,833
    Good article on this subject in the current (May) issue of WOOD magazine on page 72. They liken type 3 as epoxy without the mess. Interestingly, type 2 gave almost identical performance as t3, even outdoors.
    And, yes, they work by polymer strands, carried by water, going into the cells and locking together as the water evaporates.
  2. Glue
    Last Post: 01-17-2013, 12:48 AM
  3. Which glue?
    By Rex Bloem in forum General Woodworking Q&A
    Last Post: 07-06-2011, 01:29 PM
  4. CA glue
    By Shawn Lakes in forum General Woodturning Q&A
    Last Post: 05-19-2007, 12:57 PM
  5. OK, now the glue?
    By Chuck Hanger in forum Turning Tool Questions and Show & Tell
    Last Post: 04-27-2007, 03:12 AM
