Results 1 to 7 of 7
Thread: Freud 45 degree router bit
    I'm trying to make small boxes (not for resale!) and am having trouble getting the 45 degree miter angle on my TS. Yes, I use the Wixey gauge, yes I made the jig described in Doug Stowe's book on box making, and yes I'm about to go insane. So my thought is to cut the miter with a 45 degree Freud bit (40-114) on my router table. I welcome any constructive opinions.
    Thanks, DKT
    17,472
    havnt made any little boxes with a 45 degree router bit but have made couple chest tha thad mitrd corners..you will need to watch for tearout and use a miter guage with clamp to hold your piecer secure..hand pressure wont get it and yu can have a miscue,,not good try making a sled for your mitre slot with some fine sandpaper to help in the holding. use a clamp if yu can on your sled.. do your end cuts with a backer board, to elimate the chip out on the exit.. can do a precut as well on the tsaw to help the router work out.
    All of your concerns are valid and I've been thinking about them. My problem appears to be that my TS is nearing the end of it's life span, being 35 years old. So $35 for a router bit vs $800 for a comparable TS is probably a no-brainer.
    Thanks, DKT
    I generally use a miter sled
    on which the side lay face down but, I do have that particular bit and have used it to put 45's on tenons that meet within the leg and it works great. I would think that it would be fine for boxes as well BUT, you will have to control your material. A coping sled
Name:	Rail and backer small.jpg
    would be a good choice but a simple square backer board could be used in a pinch.
    I have the sled you show in picture 1 (although not as fancy, I use c-clamps), but I like the router sled in picture 2. Now I have to figure out how to save your picture to my desktop so I can make a similar one.
    Thanks, DKT
    17,472
    just click the pic and drag it over, or book mark this page for future refence.
    Got it, now all I have to do is built it. Thank you everybody for the good replies.
    DKT
  1. Freud 1700VCE router
    Last Post: 07-18-2012, 12:50 PM
  2. FS: Freud 5-piece Router Bit Set (NIB)
    By scott spencer in forum Old Ads
    Last Post: 01-02-2010, 12:48 PM
  3. Freud Router
    By Al killian in forum New Tools
    Last Post: 01-09-2008, 10:22 AM
  4. Freud Router Deal at Woodcraft
    By Ed Nelson in forum New Tools
    Last Post: 11-16-2007, 12:14 AM
  5. Freud FT 1700 router
    By Dave Trask in forum New Tools
    Last Post: 04-18-2007, 08:18 AM
