Results 1 to 10 of 11
Thread: captive ring tools
    North Carolina Foothills
    56
    captive ring tools
    I was thinking about trying some captive rings and have seen articles about using dental tools for the job. I would like any comments, especially about making your own tools. I might try this before expense of a specialized tool
    Oct 2007
    Schenectady, NY
    912
    Home made
    I made a pair out of old flat blade screwdrivers-one for each side of the ring. Ground out the notch with a chainsaw stone in a Dremel type die grinder. Worked fine. This was after I had bought a Crown captive ring tool and struggled with it. Made my own and haven't touched the Crown tool since.
    Don Orr
    Woodturners make the World go ROUND
    Tellico Plains, Tennessee
    4,351
    Quote Originally Posted by Don Orr View Post
    Don,
    I'm better at visual than textural descriptions... can you show a picture of your tool... I have a multitude of old flat screw drivers and a Dremel, so I could try your version ...
    Chuck
    Tellico Plains, TN
    56
    My dumb question for the day. Why a tool for each side? Can't you just turn the tool over?
    11,825
    Quote Originally Posted by gary doby View Post
    bevel up/bevel down thing.
    30,002
    Gary, Frank has it right. It would be about like using a scraper upside down.
    Feb 2009
    Southern California
    5
    I have the Crown ring tool and you do flip it for left and right.
    It has a two sided bevel, like a skew. it needs to be honed sharp. It is like cutting with a sharp scraper with no burr. Not aggressive.
    I prefer a separate tool for each side like the Sorby ring tool.
    With the Crown tool, it is a challenge to cut the ring without tear out, you need to set the tool rest above center, angle down and use a slightly skewed angle.
    Just cut off the parts that don't look like a bowl...
    Oct 2007
    Schenectady, NY
    912
    I'll try and get some pictures of the tools. The others are correct about the 2-sided thing. These tools act as scrapers with a small relief angle under the edge so you need one to work from each side of the ring.
    Don Orr
    Oct 2007
    Schenectady, NY
    912
    Home Made Captive Ring Tools
    These are the captive ring tools I made from flat blade screwdrivers. One for each side as desribed before. The bottom tool is the Crown double sided tool. It is supposed to work from either side of the ring. I had trouble with it but that was quite a while ago. Maybe I should try it again now that I have more experience.
    Attached Thumbnails Attached Thumbnails Ring Tool 1.jpg   Captive Ring Tool 1.jpg
    Don Orr
    Feb 2009
    Southern California
    5
    Hi Don,
    did you drill through and then grind?
  1. Captive Hollowing Tool Bar ?
    Last Post: 11-18-2012, 02:48 AM
  2. Captive ring goblet
    By Drew Watson in forum Lathe Project Showcase
    Last Post: 12-01-2010, 08:40 PM
  3. Captive Hollowing rigs
    Last Post: 04-30-2009, 07:15 PM
  4. Home made captive ring tools
    By Joe Fisher in forum Turning Tool Questions and Show & Tell
    Last Post: 10-12-2008, 08:59 AM
  5. D handle captive hollowing rigs?
    By M Toupin in forum Turning Tool Questions and Show & Tell
    Last Post: 06-30-2008, 04:47 PM
