Results 1 to 8 of 8
Thread: Porter-Cable Factory-Reconditioned Model 892R 2 1/4 Peak HP Router Kit
    3,134
    The write up on this router says
    "Motor transitions quickly between fixed base (included), plunge base (8931), and traditional spiral down bases (690 series)"
    Does anyone know will it fit the 690 plunge base?
    Thanks
    I found a website cpoworkshop.com that says it will transition between the fixed base, plunge base and the 690 series base.
    3,134
    What I found on CPO pretty much says the same as & quoted. It doesn't specifically say it will fit the 690 plunge base.
    If you found something specific could you tell me where to find it?
    Thanks
    The way I understand it is that it will fit all 3 bases. It even says the same thing on porter cables own website. Sorry I couldn't be of more help. Hopefuly someone out there has one and can tell you.
    3,134
    I went down to HD with 690 plunge base in tow 890 series router motor does not fit the alignment pins are not in the right position.
    They would work for a standard or D-handle base just fine because you start one pin in & the rest follow in a twisting motion.
    Bart, I found out what they are talking about. It isn't the bases themselves that are interchangeable but that the base plates themselves are. I finally found a review on the router that clarified this. This is the site. http://www.newwoodworker.com/reviews/pc893okrvu.html
    12,256
    Bart I have both the routers you mention. It was my intention to intergrate the use of the two but sadly the rack on the one needs to be removed to fit the other. Warning to everyone that rack is held in place by two very short countersunk head screws and the only thing they have to bite into is the thin wall of the aluminum casing. This rack is used to lower and raise the router. I eventually had to retap mine and put it together with epoxy to prevent it from coming loose so what was potentially a great idea for interchangability ended up being not.
    3,134
    Exactly what I discovered this morning at HD.
  1. Porter-Cable Band Saw Model (78159) Good or Bad?
    By Al Launier in forum New Tools
    Last Post: 12-10-2012, 08:31 PM
  2. Porter-Cable 690LR 1 3/4HP Router - Grizzly
    By Darren Wright in forum Hot Deals
    Last Post: 07-13-2012, 03:22 AM
  3. Porter Cable router and table question
    By Ron Jones in forum General Woodworking Q&A
    Last Post: 04-16-2012, 02:39 AM
  4. Porter Cable 890 Router Collets
    By Kevin Reid in forum New Tools
    Last Post: 12-31-2008, 11:29 AM
  5. Porter Cable router microprocessor problems?
    By Jim O'Dell in forum New Tools
    Last Post: 08-06-2007, 01:55 AM
