Results 1 to 4 of 4
Thread: Composite Hold-Down
    Alexandria, Virginia
    1,071
    Composite Hold-Down
    I found this on ToolMonger:
    Hold-downs can be very helpful in the shop, but did you ever stop to think what would happen if your router bit or table saw blade — or any other cutting tool designed for soft materials like wood — came into contact with a metal hold-down? At best you’d have a damaged hold-down, at the worst flying shrapnel.
    If the last paragraph got your imagination working, these composite hold-downs from DE-STA-CO are starting to look pretty good. The lightweight glass-reinforced nylon can produce a holding force of 200lbs, but it won’t damage your tool. The arm opens 100° to make placing and removing parts easy, and you can adjust the nylon spindle about 1/8″ vertically and 1-1/2″ along the lever arm. The hold-down comes with a slip-on neoprene cap.
    You’ll pay about $10 for one of these composite hold-downs, which is in the ballpark of a similar metal version.
    Composite Hold-Down [DE-STA-CO]
    Composite Hold-Down [McFeely's]
    Oct 2008
    1,357
    How does the composite material act if you say, run it through a router bit or maybe a TS blade? Would it be like cutting plastic or will it shatter? I've never worked with it in this form before.
    Aloha,
    They are made of a material similar to Grr-Rippers. It machines very nicely. DAMHIKT
    Montclair, NJ
    95
    I saw these too. Necessity is the mother of invention... seems I'm not the only one plowing my CNC into my hold-downs.
  1. Composite bird house...
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 08-22-2013, 02:38 PM
  2. Composite decking for "wood" table top?
    By Bill Arnold in forum General Woodworking Q&A
    Last Post: 04-19-2011, 10:52 PM
  3. Hold-down clamps
    Last Post: 03-20-2011, 08:19 PM
  4. Hold it!
    Last Post: 06-16-2009, 04:29 PM
  5. A bowl to hold something?
    By Jon Lanier in forum Lathe Project Showcase
    Last Post: 07-19-2008, 11:43 PM
