Results 1 to 10 of 14
Thread: Resawing and warped boards-bowing
    new york city burbs
    10,188
    I had to resaw alot of mahogany beams to get 1 and /34 inch width legs for chairs.
    I left an additional 1/8 almost so I can joint and plane boards.
    The boards were huge, and heavy.
    I would have loved to cut them down, but then I would not get the same amount of curved legs out of each one, so slicing the boards down in length wasnt a good option.
    After pushing these big boys through the bandsaw to cut down to width, I noticed two boards had bows in them.
    The boards are approx 8 feet each
    Each leg is 40 inches, and with the 5.5 inch boards I can cut 4 legs.
    Do I cut the legs out rough, and hope the bow is not so noticable?
    If I face joint and plane with an 8 footer, I will lose more than the 1/8th I allowed.
    Should I plane legs after I cut them rough?
    Didnt realize 2 of the boards had warps, they looked flat, I thought it was just the cut of the beam, some were narrower at ends.
    Im done for the weekend, but I will take any advice before I proceed to cut legs.
    (IM using the thicker slice in the pictures, and although only the thin slice looked warped, the larger piece is also a bit bowed)
    Attached Thumbnails Attached Thumbnails wood stuff 675 (Medium).jpg   wood stuff 676 (Medium).jpg   wood stuff 677 (Medium).jpg
    5,323
    Allen,
    Your resawing relieved internal stresses from within the beam. That's what caused the warping.
    How much warp is there in a 40" length? It looks like there's less than an inch over the total (12 foot?) length, so there likely isn't that much in at least the two end 40" pieces.
    You might be able to still get your legs cut out of the shorter lengths, but on the other hand, cutting them may release even more stresses and allow even more warpage. You won't know until you try.
    One of the fun (not!) aspects of working with a dynamic medium like wood!
    new york city burbs
    10,188
    IM going to let my wife read that Jim, and tell her the tubular steel legs still look great, even though they are from the 80s.
    Im thinking as a last resort, Ill have to plane the legs down to 1.5 inches, to get as much out if I need too.
    Ill see how they cut down I guess next week.
    After it came through the blade, it sprung apart like it was on a giant spring.
    ...After it came through the blade, it sprung apart like it was on a giant spring.
    Makes for a pretty clear demonstration of the stresses that can be hiding in a board, huh?
    4,552
    I cant see that it is going to be a problem over a 40" part and what you have there is a sign of casehardening in other words it may have been dried to fast and the inside is carrying more moisture than the out side. That board will more than likely flatten out after it acclimates in your area.
    Jay
    new york city burbs
    10,188
    I am an dufus!!!!!!!!!!!!!!!!!!!!!!!!!
    After going back out there again, and changing up the blade, (new experience, not as easy as I thought), I decided to cut down some flat pieces to see how the saw handles.
    After counting up all the thickness Ill need, I realized IM going to be short!!!!!
    Then I found by laying on the filthy floor, I believe I have put a piece of 10/4 stock, enough to fnish all legs, on the bottom of the back pile.
    That means I have to lift and repile 2 stacks of heavy wood, and then restack them again.
    My back will never forgive me for making such a stupid error.
    IM hoping I can grab my kid tomorrow night to give me a hand.
    What a moron I am.(putting hundreds of pounds of ash and maple on top of one lone piece I need)
    17,475
    allen yu can try cuttin your leg pieces to shorter lengths first easir to rip than long heavy ones..
    ...What a moron I am.(putting hundreds of pounds of ash and maple on top of one lone piece I need)
    You're no moron. You've only had a shop visit from Mr. Murphy...the guy who all the laws are named after.
    Sep 2007
    Plainwell, Michigan
    4,857
    Oh ya, I get visits from Mr. Murphy darn near on a daily basis so join the club
    Dec 2008
    falcon heights, minnesota
    5,610
    o'toole's commentary on murphy's law: murphy was an optomist...
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Resawing?
    By Mike Turner in forum General Woodworking Q&A
    Last Post: 01-13-2015, 04:34 PM
  2. Saw width for resawing?
    Last Post: 05-10-2009, 05:28 PM
  3. Resawing long boards
    By Aaron Beaver in forum General Woodworking Q&A
    Last Post: 10-19-2007, 12:34 AM
  4. Did a little resawing tonight
    By Bruce Page in forum General Woodworking Q&A
    Last Post: 07-30-2007, 07:39 PM
  5. Resawing logs
    By Jeff Horton in forum Jigs and Fixtures
    Last Post: 01-01-2007, 05:26 PM
