Results 1 to 9 of 9
Thread: Is Clear Lacquer good on pine doors?
    May 2008
    SouthWest GA
    88
    Question Is Clear Lacquer good on pine doors?
    Have some knotty pine doors unstained. I do not want to stain them but leave them natural. Would Watco brand of clear semi-gloss lacquer be a good durable protective coat? I got a deal on some from Lowes is why I ask. I will have to apply with a brush.
    Thanks
    Mark
    Sep 2007
    St. Louis, MO
    583
    I'm sure it would apply well enough, but i'm not a big fan of lacquer on things that will take abuse. It scratches fairly easily. My experience pushes me more towards varnish or poly.
    Also, water based products are difficult, if not impossible, to spot repair. In my house, with 2 little kids, i just know everything within reach will get dinged and scratched, so i stay with the oil solvent based products.
    paulh
    May 2008
    SouthWest GA
    88
    Paul, thank you for the reply. From reading the can it says good for protecting doors, so I was not sure. Also this lacquer is oil base and not water based if that makes a difference.
    Mark
    Austin, Texas
    1,448
    Quote Originally Posted by Mark Wingate View Post
    Mark
    One of the reasons I changes from solvent based lacquer to water based acrylic lacquer was that the solvent based was not as chemical-resistant as the Target USL that I now use. I had a piece that sat next to the sink and a few days later had "spots" that only sandpaper would remove. No such problems with the USL.
    Charlie Plesums, Austin Texas
    Nov 2007
    Southwest Michigan
    176
    I have used it b4 and it worked just fine.
    If it can be Moulded I'll Mould It.
    I am a Profile Knife Grinder, Carbide service, Saw grinder, Moulder Operator in industry
    Floydada, Tx
    1,941
    I use have had good luck with target coatings. Exellent products and great service.
    May 2008
    SouthWest GA
    88
    Thanks guys for all the help and info.
    Mark
    810
    Apr 2009
    Outside the beltway
    5,253
    I would seal the wood 1st with either Lacquer sealer or shellac 50/50 thinned down with alcohol then lacquer. if you use shellac you need to do the entire door not just the knot because of discoloring.
  1. home brew lacquer finish, good, bad, or ugly?
    By hu lowery in forum Finishing School
    Last Post: 06-23-2013, 04:13 PM
  2. Clear coating Pine tongue and groove walls
    By Roy Cooper in forum General Woodworking Q&A
    Last Post: 06-07-2011, 12:53 AM
  3. can someone make this clear
    Last Post: 03-18-2011, 05:48 AM
  4. Replacing and finishing pine doors
    By Kevin Reid in forum Carpentry and Construction
    Last Post: 03-21-2009, 06:46 PM
  5. matching salvaged pine flooring to existing pumpkin pine floor
    By Robert Gilmore in forum Finishing School
    Last Post: 02-23-2008, 09:45 AM
