Results 1 to 10 of 13
Thread: Some musings on my new MM16...................
    Central CA
    797
    I finally got it put together last night. I'll put a blade on it and set up the bearings today. I still feel that this machine is way, way, way more of a saw than my old G0555 and probably more than I will need or can use (while I'm here at this property anyway) but it's nice to have a top notch machine.
    The blade guard wasn't too dificult to get aligned and working properly as was mentioned by Sam Blasco and others. Thanks for the pointers on that.
    However, while cleaning it up and putting it together, I found some fit and finish items that are a little disappointing.
    First, here's a full pic of the machine to fulfill my obligation to Tyler and the Pic Police. Tyler, please accept my apologies for not getting it up sooner. Please tell me where to send the fine.
Name:	111MM16 10-52-26.jpg
    The On/Off switch is the first thing that I noticed that was kind of wonky. Mounted very noticeably crooked. This will not, nor anything else that I have to post (so far), potentially affect the performance of the saw but I was expecting a little more QC from this highly touted manufacturer.
Name:	111switch1 10-52-26.jpg
    The next thing that I noticed was, after cleaning off the table of the rust preventative, there is a handprint stained into the table. Someone put their hand on the table (signed it? ) before the rust preventative was applied apparently. I've scrubbed it with steel wool and WD40 for 20 minutes or so and this is the best that I could get it. It's much easier to see in person than it is in the pic.
Name:	111tablestain1 10-52-26.jpg
ID:	2782 Click image for larger version.
Name:	111tablestain2 10-52-26.jpg
ID:	2783 Click image for larger version.
Name:	111tablestain3 10-52-26.jpg
    Also, in the near left corner of the table, the grinding/surfacing marks are still raised considerably and can be felt quite readily. That area didn't get smoothed down apparently.
    The next thing was the blade hole cut-out in the center of the table. As you can see from the pics, the back of the hole is very noticeably curved. A penny will fit in the space between the edge of the hole and the plastic filler. And speaking of the plastic filler, it's really kind of a cheesy part. Has anyone else noticed this? It sags between the corners so that I am unable to level it with the table. If the corners are flush, the middle, between each corner, is below tha surface and material can hang up (not safe). If I raise it until the middle is flush, the corners are all above the table surface. I'm thinking of making one out of wood.
Name:	111table1 10-52-26.jpg
ID:	2780 Click image for larger version.
Name:	111table2 10-52-26.jpg
    One other thing, directly under the handle that raises and lowers the upper wheel, there is a very small dimple(?) where it looks like a piece of welding slag fell on the table and left a very small hole. There is a small raised nub that I will have to sand/file down so that it doesn't stick up.
    Anyone have any thoughts or opinions on these items? Not life changing or anything like that but a little disapponting for $2400 (on sale).
    And question, if I may? I've attached a length of cord to the saw. The 10 gauge construction cord is approximately 9/16" in diameter so it's too big for the grommet provided but too small to be snug in the plastic nut so that the cord is hanging by the wire ends on the wiring block instead of being supported byt the cord/nut grommet. This isn't a manufacturing issue by any means, just something I've run into because of the size of the cord that I'm using.
ID:	2776 Click image for larger version.
    Anyone know where I can get a grommet of a different size or some other means of wedging the cord into the nut? I could wrap black tape around the cord and use the tape for a grommet of sorts but tape doesn't really last that long in this application. I'd drill a hole and physically attach the cord to the machine before I used tape.
    Thanks very much for you opinions and thoughts.
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Tokiwadai, Japan
    2,882
    Mark,
    Have you contacted the dealer/mfg about these things... Kinda dissappointing for the price, IMO.
    That being said, I'd sure like to have one too!
    Greg
    Central CA
    797
    No, I haven't called MM (yet). These items won't affect the performance of the saw. But I did want to see what you folks had to say about these items. This is my first high end tool (no offense to my Grizzly jointer or my Uni ) and I don't really know what is acceptable on this type/level of machine.
    Thanks, Mark.
    Custom Bonehead.
    Austin, Texas
    1,453
    The MM line is industrial machinery... and if it arrived in a customer's factory with a burr, the users would grab a file and the burr would be gone in no time, without getting the foreman or purchasing folks involved. I hear MiniMax is all over Centauro (the manufacturer) to improve fit and finish for the hobby customers, and is making some progress, but it ain't perfect yet.
    The plastic filler is usually sanded flush with the table. If you make one from wood be sure to put lots of holes in it, for air flow in dust collection.
    If it is like my MM24, you can take off the stupid locking stop button (apparently required in Europe) and use the real buttons underneath.
    Have you tried cutting some wood with it?
    Incidentally I have kept my G0555 for use with a 1/4 inch blade for rough cutting curves, so I don't have to change the 1" blade on my MM!
    Charlie Plesums, Austin Texas
    mark, charlie hit the nail on the head.......centauro/scmi are industrial producers whom minimax has contracted with to build the equipment that they market to small shops and hobbiests.....to the factory and most small shops fit-n-finish cosmetic issues are non-issues....does it work? and will it keep workin`? are the big issues to these folks......i think,(but don`t know) that some of the price increases on equipment may be due to the "make pretty" asthetics that minimax is screaming for? enjoy your new saw! it`ll still be cutting long after you`ve scratched the paint, scared the table and smoked several set of guides ......as for the cord..try a wire strain relief fitting..Click image for larger version.
ID:	2785.......i made table inserts for my big saw out of baltic `cause i didn`t like the factory one.....the one on my old style 16 fit fine and is still on the saw......now let`s see some sawdust on that thing ..tod
    5,342
    Quote Originally Posted by Mark Rios View Post
    No, I haven't called MM (yet). ..This is my first high end tool...and I don't really know what is acceptable on this type/level of machine.
    Mark,
    What you've got isn't acceptable. Since you've got pictures of all the defects, I'd forward your massage, above, to MM's customer service, and their President, in the form of an email. Then, if they havent contacted you within a couple days, YOU call THEM and ask them what they're gonna do about your defective product.
    san diego
    16
    Mark,
    Congrats on the machine. Iíve had an MM16 for a few years now, and will be the first to say Iím not worthy.
    I thought the plastic filler was kind of cheesy also. I tried to make a wooden one, but the sides to the hole are anything but straight or square. So I still use the plastic filler, with the out-feed side raised a hair above the table surface height.
    One note, don't use the table top as a hand hold when muscling the machine into position. Cast iron is actually pretty flexible. I noticed a table top flatness problem a few months after I bought it. This was easily corrected by four bolts under the table.
    She ain't as purdy as a Laguna, but she'll rip thru stock that other 16 inchers will baulk at. Let's see some pics of book-matched veneer cut from a 12 inch wide oak slab.
    J
    Apprentice Wooddorker
    Future Amputee
    Central CA
    797
    Jim D. and Greg, thanks for the sentiment. However, I'm just not sure that I want to call and complain about a couple of cosmetic items on a tool. Of the times that I listed, the only thing that really kinda bothers me is somebody else's hand print on my machine. But I'm just not bothered by any of those things enough to call and complain. If the table had a corner cut off of it or something like that then I'd call but not for these items.
    Tod, the strain relief is a good idea. I'll check the two electrical supply warehouses near my house for something that will work. Thanks.
    And I think that I'll just sand down the plastic block for now and see how that works.
    Thanks again.
    Thanks, Mark.
    Custom Bonehead.
    Tokiwadai, Japan
    2,882
    Mark,
    Your hard earned $$$ are neither "hobby" nor "industrial". What could it hurt to just ask.... I doubt they will void your warranty if you do!You might even be helping out another member who buys one in the future, by nudging them to take a little closer look and make some changes... Who knows?
    Greg
    Steve Clardy Guest
    Cord relief as tod suggests.
    Sand down the plastic insert.
    Tweak the switch some to straighten it up.
    Forget about the table. It will get scratched, surface moisture stains.
    Get to using it.
  1. MM16 owners...........
    By Ken Fitzgerald in forum General Woodworking Q&A
    Last Post: 08-23-2007, 02:27 AM
  2. Zambus on MM16 - That's the way Uh Huh Uh Huh, I Like It - Uh Huh Uh Huh
    By Doug Shepard in forum General Woodworking Q&A
    Last Post: 04-16-2007, 01:35 PM
  3. WooHoo MM16
    By Steve Clardy in forum New Tools
    Last Post: 02-25-2007, 01:01 PM
  4. Woodslicer on a MM16?
    By Brian Hale in forum General Woodworking Q&A
    Last Post: 12-04-2006, 10:49 PM
