Results 1 to 6 of 6
Thread: Router bit for making BaseBoards?
    May 2008
    SouthWest GA
    88
    Anyone have a suggestion for a router bit to make a nice cut for base boards? Will be using a router table.
    Maybe once my free Lennox blade comes in I could use it in my router. A real custom tool for a custom cut baseboard!
    Mark
    17,450
    base trim
    use a ogee profile bit and lay your trim face down and run along a fence but long piece of trim can be tough,, you might find it better to go buy some already made
  3. Quote Originally Posted by Mark Wingate View Post
    Mark
    Here's some:
    http://www.freudtools.com/p-206-base-and-cap-bits.aspx
    Floydada, Tx
    1,941
    Do you have a idea asd to what you want? Here is a link to some molding knifes for idea'shttp://www.woodmastertools.com/s/support.cfm
    Sep 2007
    Bloomington MN USA
    268
    There are numerous bits out there for that pupose. Check out www.EagleAmerica.com They have lots of different profiles. The problem is the stock you are going to run through your router table. Most stock for basebords is 1/2" thick. It may be hard to find in long lengths. You can always find 3/4" ,but thats a bit heavy. As Larry said may be better to buy ready made base board.
    If you make a mistake it was part of the original plan!
    May 2008
    SouthWest GA
    88
    Thanks Larry, Charles, Al and Ron for the information.
    Mark
  1. Router table router recommendations - What are your experiences?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 11-11-2012, 03:27 PM
  2. Ryobi tabletop router table and router combo
    Last Post: 12-05-2010, 01:02 AM
  3. Making a Bowl With A Router
    By Dan Mooney in forum Hot Deals
    Last Post: 10-16-2010, 02:22 PM
  4. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  5. Replies: 5
    Last Post: 02-13-2007, 10:11 PM
