Results 1 to 5 of 5
Thread: should I use Titebond Liquid Hide Glue?
    Nov 2007
    Southwest Michigan
    176
    We have had this project at our shop that we glue up 4 2 x 2 x 38" Walnut blanks into a 4 x 4 x 38" blank when it is glued up, and it gets turned into a profile. When we get it back from the turner we have to separate this in 4 parts to be used as 4 legs of a table.
    Now we have a HARD time trying to get this apart without damaging the product, and making sure that there is 4 equal parts with in .003". (Not very much room for error) We have used Titebond I, II and had issues, then we used Titebond Liquid Hide Glue that says Its sensitivity to moisture allows for easy disassembly of parts and had no luck. (these were also used with paper inbetween staves)
    SO what I was wondering if anyone has done this before and knows how to do this correctly without damaging a $400 turning for the 3rd time?
    Any Ideas?
    Thanks Jim
    If it can be Moulded I'll Mould It.
    I am a Profile Knife Grinder, Carbide service, Saw grinder, Moulder Operator in industry
    Bob Wiggins is offline Former Member (by the member's request)
    140 miles west of tulsa
    125
    Quote Originally Posted by Jim Niemi View Post
    Any Ideas?
    Thanks Jim
    If you have been using paper the full length without success you might consider trying 4 or 6 pieces of paper about an inch or so square distributed fairly evenly along the length. It really doesn't take all that much to hold pieces like that together. Also maybe if you have waste to be cut off on each end those ends could be glued better and be a moot point when they are cut off the final product. I prefer kraft paper AKA (brown paper bag). Disassembly has to be in the exact reversal of assembly.
    Catalunya
    4,632
    I completely agree with Bob.
    Although I'm not familiar with those Titebond glues that you mention, I remember this happening to me once and the cause was that I used a too thin and porous paper that made the glue go through it and behaving as if there was no paper at all. The other cause was that on top of that I clamped the whole set.
    I learned the lesson for ever...
    Best regards,
    Toni
    Grand Rapids, MI
    383
    Curious....
    As said, not much needs to hold the turning together. I think that may be a good next attempt. However, Titebond hide glue isn't quite the same thing as the old fashioned hide glue. The "real" hide glue does soften/reconstitute very easily with water and/or a hot knife.
    I am in the process of building a woodturning business, but have not yet dealt with split turnings. I am very interested in learning which process finally meets with success. But I am sorry things aren't going well. Good luck!
    Hutch
    4,551
    Jim if you are using Hide glue then DNA and heat are your friend DNA should soften the Hide glue and heat will help release also (Hot air blower)
    Jay
  1. Hide Glue
    Last Post: 11-20-2013, 05:00 PM
  2. Glue for You??? Titebond!!!
    Last Post: 11-15-2013, 10:37 PM
  3. Which Titebond glue do you use?
    Last Post: 01-02-2012, 10:59 PM
  4. Anyone use a glue other that Titebond for segmented blanks?
    By Sue Nerlau in forum General Woodturning Q&A
    Last Post: 04-02-2011, 05:34 AM
  5. NEW liquid hide glue?
    Last Post: 04-03-2008, 03:50 PM
