Results 1 to 10 of 16
Thread: Self adhesive rule that came with my table saw....
    Nov 2008
    The Couv, Washington
    113
    I bought my Steel City table saw last year and had noticed the self adhesive rule that came with it was off by at least a 16th or more when measuring/cutting longer distances with the fence.
    The fence is in alignment with the blade so Im pretty sure thats not the problem.
    Measurements under about a foot or so are fine.
    What I did do was peel that one off and replace it with a Starrett.
    So far so good based on what I measured.
    My question is are all of the ones that come with the saw crap?
    I would assume they dont spend a lot on real accurate ones.
    What say you....
    We put the "k" in "kwality."
    The above picture is not me!!
    Oct 2008
    1,357
    I've got the same problem with my Unisaw. I even bought a Wixey and put on it but I still verify with my tape measure when I make a cut. How much is a replacement Starrett tape Craig?
    Aloha,
    9,077
    The one on my Bies was pretty good over the 30" range. I moved the tube to the right to get some extra capacity out of it. I added a Rockler tape as a replacement. It is off about 1/16" in 18" or so; really poor in my opinion.
    I added the Wixey digital gauge which is great and the current tape gets me close enough to fine tune my measurement in with the DRO. I still want to add an accurate tape because I'm just that way ;-) Many folks have talked about the Starrett so I will probably go that way.
    Nov 2008
    113
    Quote Originally Posted by Royall Clark View Post
    Hi Royall.
    It was cheap.
    I got a 3/4" x 6 ft and it was around 7.00. I figured since it was a Starrett I wont have the same problem as the cheapie. Seems more accurate.
    Will do some test cuts and be sure.
    4,553
    You folks that are using the Wixey digital gauge do you like it and how is it for accuracy I was looking at one for my saw as its getting harder and harder to see the MM on the tape for building my organ pipes
    I need to see .5mm at times.
    Jay
    9,077
    Quote Originally Posted by Jay Caughron View Post
    Jay
    This threatens to become a blatant thread-jack but:
    Royall, if your Wixey isn't dead-on when appropriately zeroed, email Barry Wixey. He will get you fixed.
    Jay, I really like the repeatability and confidence of the Wixey but you do need to calibrate it more often than I expected. Of course setting your fence next to your blade and pressing a button is not really a big deal once and awhile. I have never had it lose calibration during use or even over a couple days. I do want a decent tape still as it makes getting "in the ballpark" easier.
    4,553
    Thanks Glenn sounds like it will work great for me.
    Jay
    Nov 2008
    113
    Well I have an update.
    I was able to get pretty good cuts with the Starrett tape but still not quite where I wanted them to be.
    I also am lacking a long rule/straight edge for my measurements in my shop.
    So from what I understand use the rule on the saw to get it close but use a straight edge or rule for really accurate ones.
    So, I ordered a Pinnacle 36" rule from Woodcraft.
    I figure this will get me where I want to be.
    Oct 2008
    1,357
    There is a couple of things I want to check and then I'll contact Barry. He's too nice a guy to bug if you haven't got all your ducks in a row.
    Aloha,
    Oct 2008
    1,357
    Craig is the Sterrett tape a plastic tape? That is what I thing the problem is with the one on the my TS. I'm thinking that as I was adding it to the rail I could have stretched it while laying it out. It will grow a little over 1/16" in about 28-30". It seams too that the Wixey will grow. I sometimes wonder if it isn't the splice that makes it be erratic.
    Aloha,
  1. Recommended Spray Adhesive?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2015, 05:06 AM
  2. Laminate adhesive
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 03-11-2013, 06:32 PM
  3. Spray adhesive?
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-21-2013, 03:38 PM
  4. Proper adhesive
    By Rex Bloem in forum Jigs and Fixtures
    Last Post: 01-18-2013, 05:25 AM
  5. Spray on Adhesive that lets go when done...?
    Last Post: 02-22-2007, 11:48 AM
