Results 1 to 10 of 15
Thread: Longworth Chuck Question
    Red Deer, Alberta, Canada
    618
    I'm thinking of building a Longworth Chuck to reverse bowls to finish their bottoms. My lathe has a 12" swing. What is the largest bowl I can mount on a Longworth Chuck if I make it the maximum size for my lathe?
    I realize there are likely a number of variables based on exactly how I build the Chuck. I have a bowl with a 9-1/4" outside diameter that I'd like to mount in it. Is that bowl too large? Anyone with experience using a Longworth Chuck, I'd very much appreciate your feedback.
    .....Gord
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Gord, if the curved slots go close to the edges of the chuck, and if your rubber 'buttons' are small enough, I think you might just squeeze by, but it'll be very close.
    Let's see...
    Chuck diameter = 11 7/8"
    Slots to within 1/2" of edge = effective diameter of 10 7/8"
    Account for 1/2" button diameter = effective diameter of 10 3/8"
    618
    Let's see...
    Wow, a math major!!
    Thanks, Vaughn, I'm going to give it a try if I have time this weekend and see what happens.
    Thanks again,
    .....Gord
    become so uncommon?
    My Woodwork Site
    Math major? Me? My freshman college algebra professor suggested I drop out of his class before he had to flunk me.
    Even if the Longworth chuck ends up not fitting the bowl in question, it should be handy down the road for other pieces.
    Aug 2008
    Reno, Nv
    3,632
    After I did a Google on what a Longworth chuck was I found these links that looked good.
    http://www.crwoodturner.com/longworth/
    http://www.scrollsaws.com/images/Lat...hChuckPlan.pdf
    Ignorance is my biggest obstacle to learning
    Cotswolds, UK
    629
    Gord, always remember dependant on the actual form of your bowl/buttons you can locate it in expansion mode as well with the buttons on the inner surface, even if it does not actually grip, it can be used to align the piece and use the tailstock and revolving centre to hold it in place.
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    Nov 2008
    Tampa & NC
    432
    longworth chuck question
    They all beat me to it ,but I made one and it holds a 10" bowl,but I got those little rubber pads right on the edge.Works pretty good.I have the holes drilled in 1/2" increments to take many different sizes.
    Quote Originally Posted by Ken Ward View Post
    Ken, sounds like you're describing Cole Jaws, the ones that attach to your regular chuck and have lots of holes so you can hold different sizes of bowls. Longworth chucks has slotted holes (usually 4, 6 or 8) that are cut in a spiral to make the little rubber pads infinitely adjustable.
    Cole Jaws:
    Longworth Chuck:
    Nov 2008
    Tampa & NC
    432
    Yup,sorry bout that,but it was late when I responded.
    Hey...a pic of my first Longworth chuck surfaced on the web! How cool is that. I made that about 2 years ago. You can figure loosing 2". So a 12" will net a bowl about 10"....Bill...
  1. The Longworth Chuck...recommendations please.
    By Darren Wright in forum Turning Tool Questions and Show & Tell
    Last Post: 03-28-2015, 05:09 PM
  2. Longworth Chuck Wanted?
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-22-2014, 10:07 AM
  3. Modern Longworth Chuck
    Last Post: 09-14-2011, 03:13 AM
  4. Longworth Chuck
    By Don Baer in forum General Woodturning Q&A
    Last Post: 03-12-2010, 11:41 AM
  5. Longworth chuck
    By Rob Keeble in forum General Woodturning Q&A
    Last Post: 06-02-2009, 01:13 PM
