Results 1 to 8 of 8
Thread: cabinet-desk with hidden doors
    Nov 2008
    outside of Toronto, Ont
    183
    My mother is moving into a seniors residence and I would like to build what is almost an entertainment center to house a small bar fridge on top and a typewriter in the top drawer.
    The top drawer will be a box with front and part of the top hinged to make it easy to access the typewriter.
    The top of the drawer will also save as a table when the front is not tipped up.
    LeeValley has this hardware for hidden doors. http://www.leevalley.com/hardware/pa...305,55408&ap=1
    What alternate methods are there for doing the hidden doors?
    Here is a sketchup dwg of the proposed design. I'll probably build it 24" deep.
    Good that I previewed the posting, the full height got cropped. It is 3' 10".
    Any ideas for improvements or possible pitfalls?
    Oh yeah, the back will be open at the top for ventilation.
    Dec 2008
    falcon heights, minnesota
    5,610
    you might want to think about keeping the fridge lower, to keep the center of gravity more towards the floor.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Quote Originally Posted by Dan Noren View Post
    A low fridge might be hard for Mom to bend down to get to. Will the seniors residence allow you to put fasteners into the wall? Might be a good application for earthquake straps. At 3' 10" tall, it's not likely to be falling on top of someone under most circumstances, but if someone was on the floor trying to pull themselves up, tipsy furniture would not be a good thing.
    Alexandria, Virginia
    1,071
    I'll also add to make sure you leave enough ventilation for the fridge. At my bar, I added a small muffin fan to make sure it doesn't overheat and cause a build-up of frost inside the unit.
    London, Ontario
    3,383
    What is this "typewriter" thing you speak of...?
    Nov 2008
    183
    Thanks all for the replies.
    Art, it is actually relatively modern. It saves about 75 characters so it is possible to do corrections and positioning. She was concerned one time that the characters that were being printed were not the same as the keys being pressed. Solution; re-boot, or at least turn the power switch off-on.
    She might want the fridge on top of a smaller chest of drawers. This would leave it out in the open. Instead of having side hinged doors, i'd change the cabinet portion to a drop down door for a desk. Then the sewingmachine and typewriter could be kept in the top and pulled out onto the table for use.
    The main question is what a comfortable height is for the typewriter and sewing machine. The old office desks had a wing for the typewriter that was 26" high.
    1,071
    Quote Originally Posted by Paul Brubacher View Post
    For typing, the height of the keyboard should be where the fingers rest with elbows at right angles. For the sewing machine the height should be so that her fingertips can rest on the feed dog (table) of the machine. Because the sewing machine 'table' and typewriter keyboard are about the same height from the tabletop, (trade-offs for two different machines) it only depends how tall she is in a sitting position to get the height of her fingers with 90 degree elbows.
    Dec 2008
    5,610
    best answer for comfortable heights for her, is to ask her.
    have sit in a chair that is comfortable for her, have the tape measure handy, and have her demonstrate a comfortable height for typing, and measure up from the floor. then subtract the thickness of the desk top, and the height of the typewriter, from the top of the desk, to the middle height of the keys. when all is said and built, the keys will be within her comfort zone.
  1. Hidden Gun Cabinet
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 04-07-2015, 10:58 PM
  2. Simple Cabinet Doors...
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 02-06-2010, 11:26 PM
  3. mitered cabinet doors
    By bill walton in forum General Woodworking Q&A
    Last Post: 12-28-2007, 10:59 AM
  4. SKETCHUP Cabinet Doors
    Last Post: 05-19-2007, 07:23 PM
  5. cabinet doors
    By chris johnson in forum General Woodworking Q&A
    Last Post: 12-15-2006, 01:11 AM
