Results 1 to 8 of 8
Thread: Spindle sander questions
    17,472
    ok first thing, this was origanlly running on 220, a 1hp motor..
    amps: 14 @120 and 7 @ 220. so i can run it either way. i have both, but alot more postioning areas for 120 then 220.. so what is your opinions on what i should run it at? next question, where is the best place to get sleve's for it, and what grit do you prefer? thansk for the help folk
    Larry if you have the circuit capacity to run on 120 then do it. I worked in one shop were the tablesaw would always bog down if you cut to fast. The saw had 12 ga. wire running to it but was about 80' from the panel. because of the distance and current draw the voltage would drop on that long run. When I redid the connections on the motor to 220, the problem went away because the current draw was cut in half. As long as your hookup isn't to long you should be allright on 120.
    17,472
    Alan i am 52 ft from breaker on 12 gauge wire. and seperate circuit.gang box 4 recpts.
    Oct 2008
    1,357
    I'd use up one of the 220v slots Larry. The machine will start so much faster and won't dim the lights on you when if fires off. At least that was my experience when I switched my old TS over to 220v years ago.
    Aloha,
    That mightbe cutting it close. You can hook it up and try it. Won't hurt anything but you might be better off on 220. Before I converted that tablesaw you could hear the wires jump around in the conduit when you turned the saw on.
    17,472
    well i can always make another 220 circuit, i got space in the panel and the wire is already heavy enough to do so. one more time conduit has come threw for me! this isnt a big draw machine, like a table saw is.. good thing.. wouldnt want to be slung across the shop when i hit the drum to sand a curve.. any suggestion on grit or sleve source?
    Dec 2008
    falcon heights, minnesota
    5,610
    dunno if'n it'll hep larry, but i've gots wun o dem delta boss spindle sanders, an i pick up my sleeves at rockler. i usually use about a 120 on mine.
    benedictione omnes bene
    www.burroviejowoodworking.com
    4,552
    I used 80 and 120 grits on mine when I had one (sure miss it) and the Delta's seem to work a well as any
    Jay
  1. Spindle Sander
    Last Post: 08-11-2015, 09:47 PM
  2. spindle sander
    Last Post: 06-14-2012, 06:48 PM
  3. Anyone know anything about this spindle sander?
    Last Post: 09-10-2011, 02:19 AM
  4. Jet ovs spindle sander
    Last Post: 08-30-2011, 11:43 PM
  5. Grizzly Spindle Sander Help
    By Ben Roman in forum General Woodworking Q&A
    Last Post: 02-14-2008, 03:14 PM
Tags for this Thread
