Results 1 to 10 of 12
Thread: Lacquer brush or spray
    Mar 2009
    Lincoln AR
    142
    Can brushing lacquer be sprayed and if not why not. I looked thru the older posts and didn't find anything maybe I missed it.
    Thanks Bill
    30,014
    I've not tried it, but it's my understanding it can be sprayed if it's thinned to a viscosity your gun can handle. I believe it's a bit too thick to spray very well straight from the can.
    Mar 2009
    Lincoln AR
    142
    Ya,
    I have a 4.1 nozzle in my gun, so thinned I can get it to shoot. I was just wondering if the brush lacquer had a different leveling agent in it than the spray type. Or it seems they would just say "Lacquer" instead of calling it going to trouble of specifying brushing lacquer?
    This doesn't seem to be an easy answer because I've talked to Sherwin William and few others and they don't have a clue. I my just have to experiment with some scrap wood and then I'll be the smart one.
    Thanks Bill
    Oct 2008
    1,357
    That's all I can get in Hilo. I've squirted about 5-7 gallons so far and all I've do is add about 1/3 thinner to the cup. Works fine.
    Aloha,
    It will spray just fine Bill. All you have to do is experiment with how much to thin it and it shoots just like regular old lacquer. I've used it on my last 4 projects without a problem. Just start with about a 1/3 cup of thinner to 2/3 cup of lacquer and adjust accordingly from there.
    17,471
    i too have sprayed it after thinning, several gallons, no trouble at all.. but it doesnt brush for beans in my book i tried it and before i got a gun and it wasnt purty so i spray it now and anything else
    The "brushing lacquer" has a slower evaporating solvent(retarder added) that is the difference,by thinning the retarder is diluted to the point of acting like regular lacquer.
    Regards
    Jerry
    Mar 2009
    Lincoln AR
    142
    Good enough for me friends, I have run it by paint stores and all I get is double talk, they give this long speal then say "I think". Ya great I feel informed now!
    Guess I'll run it by my granddaughter, she thinks a lot too!
    I'm going to give a try, you have built up my confidence. I've painted a lot of cars with Lacquer. but they outlawed it, then all the cans said brush only on them.
    I'm on a fixed income like I said and I have to watch my peso's, I can't do much experimenting that's why I turned to you guys and you came through for me thanks again.
    Bill
    Honolulu, Hawaii
    1,103
    Bill, you got some good advice. I agree with Jerry about the retarder in the "brushing" lacquer. Adding thinner should counteract that if you use a fairly fast thinner, so it flashes off quickly. Unless you would be spraying in high humidity, then you might need to use a slower thinner, to help avoid "blushing". (white clouding of the lacquer finish as it sets up) Usially what we did to try to control blush was to add "retarder". Have you had any problems like that with high humidity Royall?
    I sparyed lots of old nitrocellulose lacquers in my days as a car painter (loved that stuff), and then the acrylics came along. I have been going to try clear acrylic lacquer on wood, but never have yet. I have some Sherwin-Williams "Sherwood" Cab acrylic clear gloss. Is what you have Bill, anything like that?
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Oct 2008
    1,357
    Quote Originally Posted by Tony Baideme View Post
    BUnless you would be spraying in high humidity, then you might need to use a slower thinner, to help avoid "blushing". (white clouding of the lacquer finish as it sets up) Usially what we did to try to control blush was to add "retarder". Have you had any problems like that with high humidity Royall?
    Aloha, Tony
    I've haven't had any problems with my lacquer blushing here. I've even sprayed some when it was raining and it turned out fine. Takes a long time to set up though. I've been using Deft brush on lacquer and one other but can't think of the name right now. Like I posted earlier, I run gravity fed HVLP with 2/3 lacquer to 1/3 thinner. The only problems I've ever had has been once in a while I'll get some little bubbles, but I think that is caused by laying down another coat before the last one dried completely. I just sand them out and spray.
    Aloha,
  1. Sage Brush
    Last Post: 09-13-2013, 06:45 AM
  2. Best brush type
    By Jerry Spencer in forum Finishing School
    Last Post: 12-21-2010, 10:29 PM
  3. New Air Brush
    Last Post: 05-28-2008, 04:19 AM
  4. Brush Tuft
    By Bill Simpson in forum General Woodturning Q&A
    Last Post: 12-07-2007, 04:18 PM
  5. Deft lacquer, can you spray it??
    By Jeff Horton in forum Finishing School
    Last Post: 09-08-2007, 01:02 AM
