Results 1 to 10 of 10
Thread: Better Instructions
    Aug 2008
    Reno, Nv
    3,632
    Better Instructions
    Has anyone done a Pizza Cutter from CS? The directions are a little ambigous and don't really match the mount to the handle
    30,008
    I haven't made one, but in looking through the instructions I can see how it could be confusing. What part is not working for you?
    Aug 2008
    Reno, Nv
    3,632
    The cutter tangs are pivotal and flat. If I'm drilling a round hole, how is that going to fit? Should I fill the whole thing up with CA? See attached for my ??
    30,008
    I think I'd just fill the hole with epoxy (probably stronger and less expensive than CA). You could also fill a lot of the gap with two pieces of a dowel cut in half, then fill the rest with epoxy or thick CA.
    Goodland, Kansas
    4,834
    I agree with Vaughn and have did that same thing. Get a dowel that fits the hole and cut in half. Fit the dowels on the tangs with some epoxy. Put some epoxy in the hole and insert. Holds well.
    Bernie W.
    Odessa, Tx
    1,813
    Quote Originally Posted by Bernie Weishapl View Post
    So what is the long flat piece with the two bent ends and a slot in its center for and where does it go, since it's not mentioned in the instructions, (or did I miss that part)?
    30,008
    Quote Originally Posted by Norman Hitt View Post
    I don't see where they mention that, either. From the picture in the catalog, I see it's a hilt for the blade. I guess it's just a friction fit.
    Despite the confusion, I'll bet it'll come out pretty nice, Jim. Have fun with it.
    Atlanta, GA
    194
    I made one of these a few years ago- still works and looks good. IIRC, the hole size is such that there is a a bit of a friction fit for the tangs and a little epoxy and the end cap locks it in place pretty well.
    Catalunya
    4,632
    You can make also a line of small holes of a diameter about the thickness of the two tangs together and convert them into a slot, as you would do if making a tenon receptacle.
    Best regards,
    Toni
    Aug 2008
    Reno, Nv
    3,632
    Thanks for all the input guys. I'll give it a whirl next week.
  1. Instructions? We don't need no stinkin instructions
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 12-27-2013, 11:18 PM
  2. I was just following instructions
    Last Post: 07-03-2012, 10:54 AM
  3. Shop First Aid Kit link with video instructions
    Last Post: 11-11-2010, 12:58 AM
  4. Freud SD208 dado set instructions
    By Craig Johnson in forum New Tools
    Last Post: 12-06-2008, 08:30 PM
  5. Oneway Wolverine Jig Instructions
    By Joan Keeler in forum General Woodturning Q&A
    Last Post: 11-02-2008, 02:48 PM
