larry merlau
- Delton, Michigan
Whoa, hold on a sec.
According to my calculations, if Larry is running his saw with a 2.5" motor pulley to a 6.5" saw pulley, he should be at 2083 fpm.
Changing the saw pulley only to a 4.5" would get him to 3009 fpm.
Running a 3.75" motor pulley to a 4.25" saw pulley would put him at 4779 fpm.
Running a 3.75" motor pulley to a 6.5" saw pulley would get him to 3125 fpm.
Am I correct? I suggest Larry, that you change only the saw pulley, OR the motor pulley, not both. JMNSHO.
I would agree with you Royall, on one thing, taking the bandsaw off the same circuit as your lights, would stop them from dimming when you run the saw, Putting it on a 220 circuit might help, but your table saw is probably on a dedicated circuit alone, so it gets full power.
Aloha, Tony
boy i am gettin all the islanders awaken ok i was gonna just change one tony and the motor is where i was gonna do it at.. as for power it hasnt dimmed the lights yet i have planty of power in the shop and alot of dedicated circuits..11@220 and 10@ 110 so power isnt a problem i dont htink but i was wanting to make sure i had the right motor to handle the increased pulley size.. isnt it like hooking a single horse up to the wagon with nothin on it or having it filled with hay? or isnt that how pulley changes work..?
