Results 1 to 1 of 1
Thread: Butterfly Inlays - How to
    Zushi, Japan
    739
    (Originally From This Post)
    On my recently completed project you may notice there are two butterfly inlays near the rear of the top. So I thought I would write up my method for doing them. I usually cut them on a bandsaw. But there are probably simpler ways like a router and jig, which I will probably get around to making someday.
    First I clamp the butterfly onto the top and scribe around with a scribing knife. This picture is quite after the fact but you get the idea.
    Hog out with router to about 1/16 to the scribed line
    With chisel on an angle lop off to the line. Don't go in straight down as this will go into the scribed line.
    Here you can see the angled chisel cut. Pare up to the scribed line with sharp chisel. Perhaps even just a hair under the scribed line.
    Put a taper on the edge of the butterfly.
    Send it home with a mallet.
    Then belt sand to flush
  1. V-Inlays in VCarve
    By Darren Wright in forum Computer-Aided Equipment Project Showcase
    Last Post: 10-29-2015, 04:58 AM
  2. Aluminum inlays ??
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 11-21-2010, 06:24 PM
  3. Butterfly Inlays - How to
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 12-24-2008, 06:27 AM
  4. Inlays in wood turning question
    Last Post: 11-02-2008, 01:13 PM
Tags for this Thread
