Results 1 to 8 of 8
Thread: cutting molding
    Winchester Ky.
    98
    cutting molding
    Need your expert advice. What brand and type of blade would you all recommend to use on a chop saw to cut wood frame molding? Thanks in advance.
    17,470
    freud 80 tooth, made for chop saws,,the red one
    Rochester Hills, MI
    940
    I just finished up trimming out a great room, dining room, and hallway for a customer last week. I did a three piece built up molding with a 1x6 for the base, a 1/2" cove for the shoe, and a 1-1/4" base cap for the top. I sanded, stained, and put three good coats of Minwax Polycrilic on all of the trim before I started.
    I used a Dewalt 80T fine finish blade on my my 12" Dewalt double bevel compound miter saw. (One SWEET tool ) Not a chip in site and it worked great. I was careful to always cut from the finished side and it worked fine. On one cut even being careful I did get a tiny bit of tear out if I cut from the back side but after that I was careful as to which way I cut and it worked very well. It left a SUPER smooth clean cut in the #2 or better pine I was using.
    John
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten"
    17,470
    john, red is faster than yellow but yellow makes a good blade too
    Rochester Hills, MI
    940
    Yeah,
    I've got a nice Freud that I bought a few years ago and it's still going strong. Although it is ready for a trip to the sharpener. It's only a 7-1/4" but it's the one designed to cut laminate flooring. I've installed a ton of flooring with that thing and it really works well. It's going to be worth sharpening though because it cost about $80 new.
    John
    Oct 2008
    1,357
    Wow!! 80 bucks for a 7 1/4" blade!!??? Sounds like you've gotten your money back out of it!
    Aloha,
    i use full kerfed ammana blades...for general use on a sliding mitersaw i like the 80t non-ferrous metal blades.
    Rochester Hills, MI
    940
    Quote Originally Posted by Royall Clark View Post
    Laminate flooring just eats up blades! Even good quality carbide tipped blades. The aluminum oxide that they use in the wear layer of the laminate just chews up blades. I found this out the hard and expensive way. I found this Freud which is a 54t blade with a triple chip grind. It holds up very well to the laminate flooring. I bought it when I started a 2000 square foot laminate installation job. I ruined a brand new carbide blade in short order. Then I discovered this Freud blade and it's been well worth the money. I finished that particular job and have done at least three other decent sized installations since.
    John
  1. Stacked Crown Molding
    By Pete Janke in forum Flatwork Project Showcase
    Last Post: 04-27-2015, 09:42 PM
  2. Crown molding
    By Jim Evatt in forum General Woodworking Q&A
    Last Post: 07-12-2010, 10:33 PM
  3. molding
    By ken lutes in forum General Woodworking Q&A
    Last Post: 11-17-2008, 05:06 PM
  4. Molding heads can be fun
    By Robert Schaubhut in forum New Tools
    Last Post: 09-04-2007, 02:40 AM
  5. Making molding
    By John Dow in forum Neander Woodworking Q&A
    Last Post: 01-26-2007, 03:58 PM
