Results 1 to 10 of 10
Thread: Elm Slab Bowl
    Jul 2007
    DSM, IA
    5,719
    Elm Slab Bowl
    This bowl was turned from a large bunch of elm I picked up from along the road about a year ago. I had cut a few of the logs in half, sealed them and then just put them on a shelf. I was going to rough turn a round bowl, but the wood seemed to be stable enough to just turn to finish. I decided to leave the shape the same as the bowl blank because there was some interesting grain from a small branch protruding out of it. I did add a little CA glue to hold that bit together, but the rest is holding on. I will be drilling a hole and adding a brass rod in order to enable this piece to stand on end as the last photo below shows. 13" side to side and 3" tall with 4 coats of danish oil.
    Comments/critques are always encouraged and welcomed.
    Attached Thumbnails Attached Thumbnails 100_0238.JPG   100_0239.JPG   100_0240.JPG
    My Website
    Alexandria, Virginia
    1,071
    Very nice Jeff. You spoke of a brass rod. Is there any 'left-over' wood you could make a stand with?
    Hardinsburg, KY
    277
    Nice job, Jeff. Looks like crotch figure working there, but branches will do much the same thing if you catch them just right. Looks great to me.
    Working flat so I can play round,
    Doug Miller
    Repentance Is The
    Prerequisite For
    Gods Forgiveness
    Good stuff, Jeff. I like it.
    Jul 2007
    DSM, IA
    5,719
    Quote Originally Posted by Frank Townend View Post
    Frank, I'll have to look...I was thinking the brass rod would be simple. Drill a hole stick it in, done.
    thanks for the comments.
    My Website
    Buse Township MN
    565
    I like it too!!! LOTS!!
    Every child deserves a family. Adopt. Foster. Get involved.
    1,071
    Something like this:
    Goodland, Kansas
    4,834
    Jeff that is a great piece with some great looking wood. Well done.
    Bernie W.
    Jul 2007
    Des Moines, IA
    854
    Nicely done, Jeff. I like the display idea also.
    17,475
    nice piece of elm jeff! now what to put in it?? jelly beans or some nuts?
  1. Some Slab Benches
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 05-14-2013, 01:27 AM
  2. A slab is just a sled away
    By Ryan Mooney in forum General Woodworking Q&A
    Last Post: 03-30-2013, 11:13 AM
  3. Deck over a slab
    By Mike Rathe in forum General Woodworking Q&A
    Last Post: 06-27-2008, 08:47 PM
  4. Slab Table
    By Robert Schaubhut in forum Flatwork Project Showcase
    Last Post: 10-17-2007, 05:53 AM
  5. Huuuuuge Bubinga slab available
    By tim Rowledge in forum General Woodworking Q&A
    Last Post: 04-23-2007, 05:45 PM
Tags for this Thread
