Results 1 to 4 of 4
Thread: start capacitor shot where can i get one
    Oliver Springs, TN
    1,726
    The start capacitor on my grinder is shot (delta gr450 8" vs). I have looked at a couple of places online and they range from around 45 all the way to 80 bucks. Surely there must be some place I can get it cheaper? Any ideas?
    2,784
    If I read this right, a capacitor for the motor? Take the bad one off and go to any electric motor rebuild center. You can also order from Grainger on line, and something tells me McMaster-Carr online would have them too, though I've never looked. I got 2 for a 220 volt water pump motor from Grainger here locally a few years back, about 5.00 each. Having the bad one will allow them to match the specs so you get the right one. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Oliver Springs, TN
    1,726
    Yes Jim it's the capacitor for the motor. Thanks for the suggestions too, I'll look at both.
    Jan 2009
    I live in Denton, Texas and ranched at Schulenburg, Texas.
    116
    If U have not located as suggested ---you should have a local waterwell companay. They can steer U where U need to go.
    Ray Gerdes
  1. Motor Starter capacitor burnt out
    Last Post: 08-04-2013, 12:27 AM
  2. 10 Shot Crossbow
    By Dan Mooney in forum General Woodworking Q&A
    Last Post: 11-03-2012, 04:47 AM
  3. Good shot
    Last Post: 04-22-2012, 05:39 PM
  4. Top Shot
    Last Post: 03-07-2011, 02:04 AM
  5. pig flu shot
    Last Post: 11-24-2009, 03:19 PM
