Results 1 to 10 of 29
Thread: wobbly Mini chuck problem
    11,833
    I have two chucks, both from PSI. One is the big Barracuda 4, the other is the GMC3 Mini.
    I have had the Mini for a long time and it served me well with my old lathe, the Grizzly G1067Z. It ran true and smooth.
    Then I bought my new, fancy-dancy, Grizzly G0632 EVS lathe. On the new lathe, the big ‘cudda 4 runs just fine, true and smooth. But, the Mini is wobbly awful. Problem may be that it seats thread to thread.
    I went to a friends shop, an accomplished turner, and let him try it on his Powermatic. On that it seats on the shoulders of chuck and spindle and runs true.
    However, he showed me that his own chucks (which are Rolex class expensive) do not run true on his Oneway (yes, he has both). So, to correct that, he made wood washers for the chucks to seat against. Using those, his chucks run true on the Oneway also.
    So, I come home and made a washer out of Osage Orange. Tried the Mini and still was in the Wonderful World of Wobble. Not sure what the problem is. I’m quite certain I made the ends flat and as parallel with each other as possible. I’ll try some more flattening today on the belt sander. But, would appreciate any input on this.
    Attached Thumbnails Attached Thumbnails chuck 1.jpg   OO washer.jpg   chuck with washer.jpg
    Jul 2007
    DSM, IA
    5,719
    Not sure what the problem could be Frank...hope you can figure it out of maybe someone here can. Doesn't look like you had to add an adapter to work on your new lathe...but sometimes those cause problems I've heard. Have you tried calling PSI?
    My Website
    I noticed a split in the ring you turned. when you tighten down the chuck does the split open up any? Have you tried indexing the spacerby putting a reference mark on it and then trying it at 90 degree intervals to see if it gets better or worse.
    11,833
    Quote Originally Posted by Alan Bienlein View Post
    The 'split' is pretty sturdy. I turned the washer on my big chuck with an inside grip and stressed it quite hard to test. It didn't open up at all. The pith was way off to the side and that is part of it. Strange.
    I'll try the indexing thing after I attempt to flattend the sides some more.
    Feb 2009
    Whittier, CA, USA
    512
    Have you tried taking a dial indicator on a magnetic base to it? Check for runout on rotation and against the face too. Also try it with your Barracuda as a reference. Might as well check your spindle runout while you're at it as well.
    My cheapo Grizzly set has saved my bacon when sorting out problems on my woodworking machinery. http://grizzly.com/products/Magnetic...-Special/G9849
    Have you tried the wobbly chuck again on your old lathe just to double check? Maybe try spinning it up with no jaws installed, just to check it out.
    Dan Gonzales
    Whittier, CA, USA
    Dona nobis pacem
    Frank I just saw in the second picture of the wooden ring a difference in the color of the end grain which indicates to me that the two sides are not parallel.
    It's on the side with the split.
    Cotswolds, UK
    629
    Frank, are these standard thread dimensions any help in sorting out the chuck register, you certainly don't want to rely on the thread form for alignment.
    If the attached is not big enough to read clearly then a larger pixel version is here.
    http://quest42.co.uk/woodwork/bin/AxminsterThreads.jpg
    Chas. just a traveller on the road of time.
    Bits & Pieces Gallery
    My Web Site
    11,833
    Quote Originally Posted by Dan Gonzales View Post
    Old lathe gone. But it does run true on the Powermatic.
    11,833
    Good catch, I'll skew or sand it flat and see what happens.
    11,833
    Quote Originally Posted by Chas Jones View Post
    Thanks, they are the same as the General. 1 1/4"X8tpi.
  1. GMC-3 mini chuck problems
    Last Post: 05-03-2014, 11:23 AM
  2. Problem using a chuck
    By Jim C Bradley in forum General Woodturning Q&A
    Last Post: 10-31-2009, 07:02 PM
  3. Talon Chuck Problem (probably me not tool)
    By Jim C Bradley in forum Turning Tool Questions and Show & Tell
    Last Post: 10-29-2009, 02:20 AM
  4. makita chuck problem
    By patrick anderson in forum General Woodworking Q&A
    Last Post: 10-27-2009, 01:26 PM
  5. Super Nova chuck insert problem
    By Nathan Hawkes in forum General Woodturning Q&A
    Last Post: 06-29-2009, 08:47 PM
