Results 1 to 7 of 7
Thread: Special Laminate bit for Router?
    Mar 2009
    Leominster Mass
    183
    As I said in my previous thread, I am making a router table with a laminate top. It seems like some indicate I need a special laminate router bit, I have a large set of router bits with the standard straight bits. I woudl think that the standand bits woudl work just fine, your thoughts?
    Thanks again
    Dan Thibert
    Leominster MA
    13,447
    A laminate bit looks a like a reversed dovetail bit, usually 7, 15, or 25 degree angle on them. The angle usually helps prevent chipping on the edges from what I've heard.
    Example: http://eagleamerica.com/product.asp?...cd2=1240018845
    Laminate is generally trimmed at a slight angle to avoid the possibility of being snagged. I have done this with a sanding block and 400 grit paper. Route it flush with your existing bit and then bevel it with the sanding block at about 10* or so.
    P.s. Man, Darren is fast.
    Mar 2009
    Leominster Mass
    183
    You guys are awesome, I am new to this and will have many questions. Some simple and some not.
    Dan Thibert
    Leominster MA
    Quote Originally Posted by Dan Thibert View Post
    We all had questions and most of us still do ;-)
    The only dumb questions are the ones you never ask. If there is one thing I've noticed in my short time stalking this forum, people are more than willing to offer help and suggestions...some of them even seem like good ideas
    Go ahead and run clown, with those big floppy shoes, you won't get far.
    Odessa, Tx
    1,813
    Darren is correct, AND if you use a sanding block to bevel that edge, "Be CAREFUL" as you are doing this, because the edge of the laminate on that 90* angle is "SHARP" and WILL slice your fingers, (which is another reason for beveling that edge as I found out MANY Years ago).
  1. Laminate Trim Router.... Which one?
    Last Post: 11-02-2013, 09:00 PM
  2. Veneer/laminate router related question
    By Westley Rosenbaum in forum General Woodworking Q&A
    Last Post: 04-10-2009, 04:13 AM
  3. Rockler Router Table and Router Startup Special
    Last Post: 08-22-2008, 02:56 PM
  4. Router Bit Set Special - MLCS
    Last Post: 08-05-2007, 11:56 AM
  5. Where, what and how to buy laminate for a router table top?
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-16-2006, 02:25 PM
