Results 1 to 10 of 11
Thread: Another Jacaranda Natural Edge
    30,002
    This is another piece of the wood I got from the neighbors down the street. The finished bowl is about 10" x 9", and about 4 1/2" to the tip of the highest of the three wings. It's finished with Formby's Tung Oil mix and buffed. This one didn't have the curl some of the other jacaranda has had, but it's still a pretty cool piece of wood. I don't know how it got the green stain, but it was there from the start. Despite the varying thickness of the bark, the wall thickness is pretty consistent at about 7/8" to 1/2".
Name:	Bowl 061 - 02 800.jpg
ID:	31288 Click image for larger version.
Name:	Bowl 061 - 01 800.jpg
ID:	31289 Click image for larger version.
Name:	Bowl 061 - 03 800.jpg
    Comments and critiques are always welcome -
    Looks super Vaughn!
    Looks like you are putting your time to good use!
    Nov 2008
    Ireland
    28
    I think that is really lovely. Any chance of you nipping over to Ireland to give me some tuition.........pleaseeeeeee?
    Brendan
    Pickles Gap, Arkansas
    271
    That's a great NE, Vaughn - good stuff! Love these NEs that have >2 wings.
    If you have a pulse you have a purpose...
    12,246
    Nice bowl Vaughn. Is there any trick to getting the bark to stay on and in place. I have never turned anything like this but would have thought that when turning it green, the bark would have hooked and come away. And then when its dry well I would have thought it would just crack off.
    Any insight you can offer?
    Alexandria, Virginia
    1,071
    Same answer as the answer to the Question "How do you get to Carnegie Hall?"
    "Practice"
    Goodland, Kansas
    4,834
    Vaughn that is beautiful. Really like the wood. Form and finish are great.
    Bernie W.
    30,002
    Quote Originally Posted by Frank Townend View Post
    "Practice"
    Frank's right about the practice part. I can't really discuss the other approaches for keeping the bark on a piece since they involves either religion or cursing. Don't want to violate CoC.
    Seriously Rob, some bark holds on better than others. It's usually easier to cut (and less likely to let go) when the wood's green. For any of it, a light cut and sharp tools are vital. This piece had a section that started to detach itself from the sapwood as it dried, but I reinforced that section with epoxy before I did the finish turning.
    Cornwall, England
    392
    It also helps if you cut from the bark to the wood. Nothing worse than just doing the final touches and a little bit flies of into the oblivion of the shavings DAMHIK
    Pete
    Rhode Island
    800
    Vaughn,
    Gorgeous as always.
  1. Persimmon natural edge
    By Richard Madden in forum Lathe Project Showcase
    Last Post: 10-14-2013, 10:20 PM
  2. Jacaranda Natural Edge Winged Bowl
    Last Post: 05-23-2009, 04:11 AM
  3. Natural Edge Bowls
    By Wayne Bower in forum Lathe Project Showcase
    Last Post: 12-01-2008, 08:45 PM
  4. First Natural Edge Bowl
    Last Post: 02-12-2008, 09:17 AM
  5. Ash Natural Edge
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 09-15-2007, 04:00 PM
