Results 1 to 10 of 16
Thread: Lacquer over oil
    Oct 2008
    Sacramento, Ca
    7
    Lacquer over oil
    Just trying out some finishes on my turnings. On a piece or two I just sprayed rattle can lacquer and was unimpressed with the finish, it seemed like it did not bring out the grain to the fullest. Also I have been turning some natural edge with a lot of voids within the bowls (manzanita root burls) and it seems it is hard to get in the crevices without overspraying and getting a run.
    Next question... is spraying lacquer over oils a problem? I found that using the oils first gets good coverage in the cracks and crevices, as well as bringing out the grain. Then it seems like they need more coats of lacquer
    Goodland, Kansas
    4,834
    What kind of oil are we talking. BLO or like Danish oil, etc?
    I use Antique oil and don't put anything over the top. If it is BLO I use minwax wipe on ploy over it.
    Bernie W.
    30,017
    I use lacquer over Antique Oil and Tung Oil mix, and so far have had no problems. I do make sure I give the oil finish a few days to cure before covering over it with the lacquer.
    I believe there are others who disagree with this, and say oil and lacquer don't mix, but I've done dozens of turned pieces this way and had no known failures yet.
    Keep in mind that if you're using a wipe-on oil finish like Danish Oil, Antique Oil, or one of the Tung Oil blends, you will get more and more gloss as you apply additional coats. I like using the lacquer to even out the sheen, or to add gloss to pieces that would be difficult or impossible to buff.
    Jul 2007
    DSM, IA
    5,719
    I have sprayed rattle can laquer over danish oil quite a few times without problem. I did let the oil dry for about 5 days before applying the laquer using the "if you don't smell the oil, its ready for laquer" idea.
    My Website
    Oct 2008
    Sacramento, Ca
    7
    Oils
    I put on 100% tung oil on one and mineral oil on the other.
    Oct 2008
    Sacramento, Ca
    7
    Quote Originally Posted by Bernie Weishapl View Post
    I am fairly new to turning (1 year) What type of finish does the antique oil give, and how many coats, sanding in between? I have seen your work around and am jealous of the finishes. I have used BLO with the CA finish on the pens but not by itself, how does it compare?
    30,017
    Quote Originally Posted by Chris Krohn View Post
    Tung oil will cure, but it takes a long time (possibly several weeks). Like Jeff mentioned, when the smell goes away, you're probably OK to put lacquer over it. Mineral oil, on the other hand, never really "cures". I'm not sure if there's a good way to apply lacquer over mineral oil. You might be able to seal it with a sprayed-on coat of shellac, but I'd test it on a piece of scrap before committing to it on a turned piece.
    Antique Oil, Danish Oil and the Tung Oil blends like Formby's are essentially a mix of some type of varnish, BLO or tung oil, and thinners. I like using them on turned pieces, since you get the grain-popping qualities of BLO or tung oil, and a protective membrane finish like varnish. They are generally applied heavily with a rag, left to soak on the piece for a few minutes, then the excess is wiped off. As you repeat the process (and perhaps sand very lightly with 400 or so sandpaper between coats) the finish will become more and more glossy. I usually go with two or three coats...I just keep doing it until I like the way things look.
    BLO by itself provides an attractive "hand rubbed finish" look to a piece, but is doesn't form the protective membrane finish that the wipe-on varnishes like Antique Oil give.
    On my pieces, I give a lot of the credit for the finish to having a three-wheel buffing system like the Beall. (Mine's from Don Pencil, but it's essentially the same thing.) Buffing can turn a a nice finish into a great one.
    Oct 2008
    Sacramento, Ca
    7
    Is the 100% tung oil good on its own, or should I thin it with something? It is my understanding, not to get a whole nother side topic going, but, the 100% makes it food safe, rather than having the extra additives in it.
    30,017
    Chris, these days virtually any finish is "food safe" after it has cured. Adding thinners to pure tung oil can help it penetrate the wood better and speed up the curing process, and once they flash off, you're still left with a "food safe" coating.
    Westphalia, Michigan
    955
    Chris, I used to use the BLO/ CA finish on some pens and have gone to putting some sanding sealer on after the BLO to seal it. It seems to work in that I now get a good build of CA without the blotchy finish I used to get. I found that the pen would look great until it was used for a time and then I realized that the finish had gaps in it. (go figure, glue doesn't stick to oil) I use a sanding sealer that is shellac based. I haven't used any antique oil yet but from Vaughn's description I will give it a go.
  1. Lacquer
    By Scott Turner in forum Finishing School
    Last Post: 05-15-2015, 04:28 PM
  2. Building lacquer
    By Dave Black in forum Finishing School
    Last Post: 11-02-2011, 02:19 PM
  3. Lacquer life
    By Bill McQueen in forum Finishing School
    Last Post: 11-27-2009, 07:55 PM
  4. Lacquer question
    By Al killian in forum Finishing School
    Last Post: 09-07-2009, 06:57 PM
  5. where is the lacquer?
    Last Post: 08-24-2007, 03:30 PM
Tags for this Thread
