Results 1 to 8 of 8
Thread: Tub Surround Tile Grout Question
    I'm in the final stages of probably the most unsatisfying project I've ever worked on - re-grouting the tile surround in our old bathroom.
    The question: Should I seal the grout or not?
    I've heard pros and cons for both options.
    Thanks in advance for any input.
    Wes
    Oct 2008
    1,357
    I seal my grout. Keeps staining and mold to a minimum. Mold and mildew are a constant battle here. Not positive, but I think I heard once it helps slow down water from passing through the grout. YMMV.
    Aloha,
    Dec 2008
    falcon heights, minnesota
    5,610
    seal it good, never worry about it again...
    benedictione omnes bene
    www.burroviejowoodworking.com
    +1 on sealing. It's cheap and the hard part of that project is over. Don't go short on it now. I did the kitchen counters in my last house. The grout stayed blinding white with just spray cleaner and paper towels. Well worth the effort to seal.
    12,260
    Ok guys I have never heard of sealing grout. So what do you use. I mean the obvious is a sealer but what is it? Can you quote a brand or what the liquid is, how is it applied does it just wipe off the tiles?
    Oct 2008
    1,357
    Rob, can't think of the name right now but it's a penetrating sealer that I believe has silicone in it and a petroleum base... could be wrong. HD has it and it was about 35 bucks a quart. Goes along ways though.
    Aloha,
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    It is a silicon sealant and all grout should be sealed and repeated every 6 months. it is simple as you spray it on the tile and grout and wipe it around with a sponge. It just stops water from penetrating the grout and all the ugly mold and mildew from forming in it. At leat that is what I was trained to do and have always done for years and never had a problem with my tile jobs.
    Thanks guys. Sealer it is. Now all I need to do is wait for it to cure and go to town on the sealer.
    Thanks again!
    Wes
  1. Mystery Tile
    Last Post: 07-16-2013, 01:14 PM
  2. Ridgid R4030 Tile Saw
    By Darren Wright in forum New Tools
    Last Post: 11-14-2012, 02:34 PM
  3. Tile saw
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 11-10-2012, 09:31 PM
  4. Any one know about this tile place in New Jersey?
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 09-07-2009, 12:01 AM
  5. Tile flooring question
    By Ed Nelson in forum Carpentry and Construction
    Last Post: 12-01-2007, 01:51 PM
