Results 1 to 3 of 3
Thread: Vineyard Table from Fine Woodworking
    Lima, NY
    53
    I saw this interesting table design in FineWoodworking and decided it would be a good Sketchup project. The table is similar to a trestle table in construction, except that the cleats are hinged instead of joined to the legs, allowing the tabletop to flip down or be removed for storage and transportation. The harp-shaped structure pivots outward to support the tabletop when the tabletop is set up for use. The SketchUp model is uploaded into my "Creekside Woodshop" collection in the Google 3D warehouse.
    http://sketchup.google.com/3dwarehou...eb5336&ct=mdcc
    Attached Thumbnails Attached Thumbnails Vinyard Table-render-01 (Medium).jpg   Vinyard Table-render-02 (Medium).jpg   Vinyard Table-render-03 (Medium).jpg
    12,256
    Hi Ron
    Great Sketchup drawing. I like the table design too.
    Was just thinking it would make a great fold away card table, pitty the legs dont rotate as well then it would be a flat folded object and be able to be stored either under say a bed or flat against the wall with the minimum of space. Guess some engineering on the tennon joint could be done to enable it to be a rotating joint?
    Tellico Plains, Tennessee
    4,351
    You could probably put a round tenon on the bottom of the leg into the foot of the table, but I'm thinking you might loose some strength there. I like the design.. will make a pretty table.
    Chuck
    Tellico Plains, TN
  1. Now this is fine woodworking!
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 05-16-2013, 01:36 AM
  2. New Fine Woodworking Quiz
    By glenn bradley in forum Off Topic Discussion
    Last Post: 07-16-2009, 06:49 PM
  3. Fine Woodworking Subscription
    Last Post: 04-20-2007, 02:06 AM
  4. Not exactly fine woodworking but.....
    By Greg Ladd in forum General Woodworking Q&A
    Last Post: 03-25-2007, 01:54 AM
  5. Fine Woodworking magazine
    By Bill Antonacchio in forum Off Topic Discussion
    Last Post: 01-08-2007, 02:06 PM
