Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: base idea scratched, breadboards were a failure!
    new york city burbs
    10,188
    If I make a base for a coffee table like this picture(sorry for the rough sketch)
    measurements arent exact yet, just estimates.
    I want to allow for movement since the top will be glued up maple or ash, not sure yet, and Id prefer to not have any type of clips exposed to view.
    The top will be approx 24x56.
    If I just put floating tenons? in the stretcher, mortise them only into center board of top, will that be enough to hold the top down if table is lifted by top?
    I thought about boring into the bottom of the stretcher, but if the top is only 1 inch or less thick, theres not alot of wood to grab.
    Its a learning process for me. I dont want to use a standard apron and legs.
    any help would be appreciated.
    Pocket joints would be exposed, dont want to put plugs in if I can prevent it.
    Allen they make something called a figure 8 cause it looks like an 8. You mortise out on top of the legs and fasten it with a screw , place your top on and fasten it down with the other hole but don't make the screws tight to allow for movement. I'll try to find a picture of one for you.
    Highland woodworking has them. just look under figure 8 tabletop fasteners. Package of 12 for like 3 bucks.
    Dec 2008
    falcon heights, minnesota
    5,610
    hi allen! based on your measurements in the sketch, i did it up quick in sketchup. i went with a width of 8 inches for your cross brace, and added 2 inches in length for the stopped dovetails. the stopped dovetails are 6 inches, and the remaining 2 inch overlap hides the end of the stopped dovetail dado nicely. i went with the dovetails because they are a good strong joint. as for attaching the top, i'm kind of iffy about that, since in the sketch, you only have 8 inches supporting a top that would be 24 inches wide. to me, that would be a fairish amount of stress on the glue joint. here is what i came up with, with measurements, and exploded. hope that will help.
    Attached Thumbnails Attached Thumbnails allen coffee table.jpg   allen coffee table 2.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    new york city burbs
    10,188
    nice sketch dan, looks pretty much what base Im looking for.
    Alan, I have a box of the z-clips. they work like the figure 8 clips.
    Im thinking there might not be any other way to attach it firmly, eitherfigure 8 or z style clips.(just didnt want anything exposed on underside either, since none of the underside is really hidden)
    just wanted to make sure I wasnt missing anything or some secret.
    Dec 2008
    5,610
    only other way i can think of to attach the top, is to borrow from breadboard ends, and drill a couple of elongated holes on each end, secure the top with something like a lag screw, or panhead type of screw, then cover up the opening with a decorative insert.
    Apr 2009
    Remlap,Al
    87
    if you use dovetails you could run a female on the cross member and screw a male in the bottom of table top. made it the same lenght as the exposed crossmember and when you slide it down in the legs it stops left/right and up/down movement plus lets you take it apart.
    new york city burbs
    10,188
    putting screws at different locations to secure the dovetail to bottom, will that allow all the wood movement Id need?
    13,448
    Just keep them evenly spaced over the top...they'll hold it down
    Put one screw in the center and the screws on the ends just elongate the holes and when you insert the screws don't tighten them just snug them up to allow movement.
  1. successful failure
    By Frank Fusco in forum Lathe Project Showcase
    Last Post: 08-08-2011, 10:23 PM
  2. itch scratched
    Last Post: 11-16-2009, 06:30 PM
  3. trestle table base idea
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 10-29-2008, 01:24 AM
  4. Fantastic DP base idea
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 05-27-2008, 10:51 PM
  5. Tablesaw Base Cabinet--Wild Hair Idea
    By Dave Richards in forum General Woodworking Q&A
    Last Post: 03-03-2007, 04:25 AM
