Results 1 to 9 of 9
Thread: Shop built plane hammer
    Bucks County PA
    149
    Here's some photos of a the plane hammer I finished up last night.
    The 1" dia brass head weighs about 4 oz and is faced with a "plug" of end grain bubinga on one side. The end of the brass head with the bubinga has a 7/16" hole drilled in it. The bubinga plug was turned a bit over sized and featured a tenon on the back to match the hole in the brass. Then it was epoxied in place and the assembly turned smooth. The 3/8" dia hole for the handle was drilled with a milling machine and a "V" centering jig back when I cut the stock to length.
    The handle is hickory and is about 9" long. It was turned to shape and then shaped with a spoke shave, rasp, and sandpaper. The wedge in the handle is also hickory and was glued into a slot in the end of the handle after I installed the hammer head. The wedge really does a great job of making the hammer feel very solid.
    I signed my name using a wood burning pen (another useful relic from my wood turning days!) and the handle was given several coats of Danish oil.
    I tried it out on a coffin smoother and was very pleased with the feel. It allows me to adjust it a lot finer than the rubber/urethane hammer I was using before.
    Overall I'm pretty pleased with the outcome. I had a couple false starts when I first began this project but all in all it came out the way I wanted.
    Thanks for viewing!
    See ya around,
    Dominic
    Central NY State
    3,374
    Looks like a nice project and a very useful tool. Good work Dom.
    Bellingham
    2,450
    Very nice! It looks like you managed to get that coffin smoother tuned up.
    3,135
    Oh man Dom.
    you hammered it.
    Right on the button.
    Central NY State
    3,374
    Hey Dominic, where'd you get the brass head? Got any extra?
    Ken
    Villa Park, CA
    1,407
    Quote Originally Posted by ken werner View Post
    Ken
    You can buy it from On-line Metals, but you probably have to buy a minimum of a foot so sharing with friends is a good idea. Or make a bunch of hammers and give them as gifts to woodworker friends.
    Mike
    [I have a tutorial on how to make those hammers on my website.]
    Ancora imparo
    Central NY State
    3,374
    Quote Originally Posted by Mike Henderson View Post
    Thanks Mike, I'm hoping Dominic wants to share with his friend Ken. I've seen your tutorial and it's a good one.
    Ken
    Bucks County PA
    149
    Scrap piece from work
    Ken
    Ken,
    I wish I had a piece I could send you. But sadly, it ain't the case! The brass for this hammer came from a small piece of scrap from my job. I used pretty much all of it up on this one hammer.
    As Mike suggested, you can get some online pretty reasonably.
    See ya around,
    Dominic
    Bucks County PA
    149
    Thanks for the compliments!
    Thanks for the compliments gang!
    See ya around,
    Dominic
  1. My best day in my shop since i built it
    Last Post: 08-16-2010, 02:22 AM
  2. Shop built saw vise (long)
    By Dominic Greco in forum Handtool Project Showcase
    Last Post: 10-30-2009, 09:35 PM
  3. Built some cabinets for my shop...
    By Craig Johnson in forum Jigs and Fixtures
    Last Post: 03-29-2009, 12:27 AM
  4. Another plane plus adjusting hammer
    By Toni Ciuraneta in forum Handtool Project Showcase
    Last Post: 06-20-2008, 11:33 AM
  5. Custom Built Plane
    By Travis Johnson in forum Neander Woodworking Q&A
    Last Post: 03-01-2007, 08:18 AM
