Results 1 to 10 of 23
Thread: Shotgun day.... Day 2
    Oct 2008
    1,357
    Shotgun day is what the day turned out to be. Had too much on my mind to do any serious wood cutting or layout, but needed to do something. I thought of the push block that Stu posted in a Jig and fixtures thread and made one of those littler rougher looking than stu's but it works Next I looked over at a couple of dado jigs that I copied from Glenn Bradly, that needed to be finished so that got marked off the todo list also. By the way, thanks Glenn!.
    Walked over to the sanding center I put together and figured I'd clean up the old belt/disc sander. I had some new belts for a while but just never got around to changing it. Got that done but then realized the belt wouldn't track in the center of the wheel. Some how part of the adjuster assembly got bent. So I took that apart, straightened it out and now that's fixed The photo shows the part that was bent. It is very soft steel. Geez I'm on a roll I next set my sight on my DW 733 planer. With 160 bf of sapele to work over it was time to install the new blades that I bought last fall. That went pretty smoothly as I had taken the blades out last summer and hit'em a lick with a sharping stone until I got the new ones so the process was still kinda fresh in the brain.
    After that I did 2 loads of laundry, made dinner, and swept the kitchen floor How was your day
    Here's some photos to go along with the story!
Name:	IMG_8736 (Small).jpg
Name:	IMG_8737 (Small).jpg
Name:	IMG_8739 (Small).jpg
Name:	IMG_8752 (Small).jpg
Name:	IMG_8734 (Small).jpg
Name:	IMG_8740 (Small).jpg
Name:	IMG_8745 (Small).jpg
Name:	IMG_8746 (Small).jpg
Name:	IMG_8751 (Small).jpg
    Aloha,
    Rhode Island
    800
    Great day.
    Where are the pics of you in your apron sweeping the floors???
    Quote Originally Posted by Chuck Beland View Post
    Great day.
    Hey, my day is going just fine, no need to see those pics
    Royall, looks like you had a great day!
    BTW, if you have any more of them safety push pads around, you can make more than one push pad for the tablesaw. The one you show is good for smaller stuff, but one about 6" wide is really nice for the bigger boards, that are just too small to put through by hand.
    Honolulu, Hawaii
    1,103
    Shotgun day....
    That's why I'll use "The Grr-Ripper (or however it's spelled )
    And thanks again.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Quote Originally Posted by Tony Baideme View Post
    And thanks again.
    Aloha, Tony
    Yep, the GRR-ripper is on my short list of tools to buy!
    Dec 2008
    falcon heights, minnesota
    5,610
    a few more days like that royall, and you'll be catching up to my week...
    i almost can't wait to get back to the peace and quiet of work...
    benedictione omnes bene
    www.burroviejowoodworking.com
    And thanks again.
    Aloha, Tony
    That's spelled right but, just in case there is a misunderstanding . . . it is not a floatie toy for the pool .
    Royal, what a great day. I love it when a day goes like that; line 'em up and knock 'em down.
    Aug 2008
    NorCal, USA
    495
    Quote Originally Posted by Royall Clark View Post
    . . . but needed to do something.
    Royal,
    I don’t sere any bellows or pipes in the background of your pictures. Got that all done already and have it sitting in your house? Got pictures of it?
    Floydada, Tx
    1,941
    Nice start to the day, but what did you do after lunch. Please enough bad mental imagges floating around here(spandex) dont need to see you in a maid outfit.
    Oct 2008
    1,357
    Well I went out to the shop today and decided it was time to take the saw off the mobile base. It hasn't move sense I parked it where it is and I see no reason to move it It's a hassle to clean around too. Started out taking the out feed table off then the fence rail and the right extension table. Pulled the wings off and Troy (my neighbor) helped lift the saw off the base. Cleaned the saw innards out and loosened the top up and rest the miter slot to the blade. Got the saw back together and adjusted the fence to the miter slot and zeroed the blade and rest the TS Wixey and courser on the fence. Set the blade to 90* with the other Wixey and still had time to sweep shop up! Now what to do with the old mobile base Probably put it in the attic untile I die and let someone else wonder about
    it
    The one thing I wish I had done while the saw was apart is seal up the inside dust tray/baffle/shelf or what ever it's called with duct tape. Just too much sawdust leaks out underneath the machine. But I forgot
    Whats wrong with the calipers??? I'll tell you what's wrong with it. I can't read it anymore I use to use this for building transmissions but then along came digital and I used it and put this one away (Dad used it for reloading bullets years ago) When I quit turning wrenches I sold the digital (like a big dummy) and now I can't see the small lines good enough to read the darn thing
Name:	IMG_8753 (Small).jpg
Name:	IMG_8754 (Small).jpg
Name:	IMG_8757 (Small).jpg
Name:	IMG_8758 (Small).jpg
Name:	IMG_8767 (Small).jpg
Name:	IMG_8768 (Small).jpg
Name:	IMG_8769 (Small).jpg
Name:	IMG_8775 (Small).jpg
Name:	IMG_8778 (Small).jpg
Name:	IMG_8780 (Small).jpg
    Aloha,
  1. Shotgun Stock
    By Roy Millsaps in forum Carving
    Last Post: 08-08-2014, 04:24 PM
  2. Over and Under Shotgun
    Last Post: 05-24-2013, 02:45 AM
  3. 12 Gauge Shotgun Shell
    Last Post: 02-18-2011, 04:28 PM
  4. Shotgun Shells
    Last Post: 11-11-2010, 06:06 AM
  5. I need some shotgun help please...
    By Chris Barton in forum Off Topic Discussion
    Last Post: 11-04-2007, 11:55 PM
