Results 1 to 6 of 6
Thread: seeking rail & stile bit set
    I'm either blind or corn-fused as usual but I haven't been able to find this profile for a rail & stile bit set. Any body got an Idea where? I looked in MLCS but .... in a double roundover, or would that be cut one side and then the other. But the matching stile??? They have it in an Entry door set but that is for a 1 3/4" thick piece, I need 3/4" thick. Somebody did it 100 years ago as these are for replacemnt shudders damaged in a fire...
    Couldn't you run a round set positioned to center the slot and then flip the material?
    http://www.holbren.com/images/T/t-360-234.gif
    Odessa, Tx
    1,813
    Glenn, the Stile looks like it would work, but I don't think the Rail would, because the square cut in the bottom of the picture would take out the wood that should be there in the curve radius, (or at least that is what it looks like to me).
    I know I have seen those bits in someone's catalog, but it has been a while. Maybe it was Infinity or that other Newer co in Fla when they started making bit sets to duplicate the older styles of furniture.
    Quote Originally Posted by Norman Hitt View Post
    You are absolutely right. I didn't play that through thoroughly enough in my mind. Sorry about that.
    Indiana
    130
    What about if the squared cut part could be removed I ran across This Bit on rockler and it looks as though it can be removed so that the barring can be changed.
    not sure if the size is what you will need though.. still looking around.
    Feb 2009
    Oklahoma City, OK
    158
    Even though it's a rail and stile it really resembles a tongue and groove type setup. Couldn't you take the groove side (the stile), cut the groove either with your router/table or your table saw then take a 3/8" round over bit to round the edges over? For the "tongue" side (the rail), I'm thinking a 3/8" cove bit cut on one side, flip the wood over, then cut the same thing on the other side would work. I may have the measurements off and it may be a 1/4" set that you need depending on how wide a groove you wanted to cut.
  1. Rail and Stile
    By Steve Southwood in forum Designs, Plans and Sketches
    Last Post: 08-09-2011, 08:56 PM
  2. Replies: 0
    Last Post: 11-11-2008, 04:48 AM
  3. Aligning Rail & Stile Router Bits
    By John Clasen in forum General Woodworking Q&A
    Last Post: 04-02-2008, 06:34 PM
  4. Rail and Stile profile cutting
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 05-12-2007, 10:00 PM
  5. Rail and Stile Question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 05-10-2007, 07:04 PM
