Results 1 to 7 of 7
Thread: Manual for Ryobi 16 inch scroll saw
    Mar 2009
    Leominster Mass
    183
    A friend gave me a old rusted Ryobi scroll saw which needs some help getting cleaned up but still works. There was no manual with it and I could not find one on line.
    I figured most every thing out, but it had two sets of different blades with it. One set has catches at both ends that hook into the upper and lower arms. The other set of blades is simple straight metal blades a bit thinker with no catches. I am not sure if these blades just do not go with this unit, or if there is another was to attache the blade?
    Thanks again
    Dan
    Dan Thibert
    Leominster MA
    Alexandria, Virginia
    1,071
    Dan, they are available for free several places on the Web.
    Since I don't know what your model number is I couldn't find the specific manual.
    Parts Breakdown Drawings and Lists can be found here: http://odref.com/pdf/Ryobi-Power-Tools/
    Mar 2009
    Leominster Mass
    183
    From the drawings it looks like I may have the SC160 since the table is rectangle and not rounded.
    Dan Thibert
    Leominster MA
    1,071
    Quote Originally Posted by Dan Thibert View Post
    No part number anywhere on the saw?
    I have only found the parts diagram, but I am at work and a bit busy. I realize you have done an extensive search; maybe send RyobiUSA an E-mail as ask them where you can get a manual.
    Mar 2009
    Leominster Mass
    183
    I called Ryobi and they are sending me out a manual at no change
    Now all I have to do it take it apart and clean all the rust off of it, which there is alot.
    Still have to figure out how to attach the straight blades to it, seems there is an addapter and I beleive I at least saw one peice. Time to look at this freebe a little more carefully.
    Thanks
    Dan
    Dan Thibert
    Leominster MA
    1,071
    Well there we go Dan.
    Mar 2009
    Leominster Mass
    183
    Other than being able to put the blade into a smaller hole ios there any real difference between using the straight or pinned blades? Sears has a variaty pack of pinned blades for $12 and I an thinking I will just pick those up.
    Seams there are two blade adapters that come with the unit in order to use straight blades and one is missing. (anyone have a spare)
    This unit is old and pretty rusty but I think with a lot of elbow grease and some TLC it will come back to life for a while anyway.
    Thanks
    Dan
    Dan Thibert
    Leominster MA
  1. Looking for an owners manual
    By Guy Bratt in forum General Woodworking Q&A
    Last Post: 07-13-2014, 03:38 AM
  2. Replies: 3
    Last Post: 02-20-2012, 02:16 AM
  3. Rockwell Delta 24 inch Scroll saw question
    By Rob Keeble in forum Old Iron
    Last Post: 01-05-2012, 01:39 AM
  4. 3/4 inch vs 1 and 1/8th inch thickness question
    Last Post: 02-12-2010, 12:53 AM
  5. Replies: 1
    Last Post: 11-21-2009, 01:48 PM
