Results 1 to 10 of 16
Thread: What glue to use?
    Apr 2009
    Outside the beltway
    5,250
    What glue to use?
    Different project require different glue.
    Yellow glue for wood it has a great bond but I prefer Rabbit skin glue for an even greater bond.
    Good thing to know if you use a epoxy tootsie roll wood filler use rabbit skin glue 1st let it dry and the wood fill will adhere better.
    Yellow glue and rabbit skin glue work best with you apply a coat to each piece and then let tack up for 15 minutes and then join together.
    13,438
    Good tips Dave. Where do you get the rabbit skin glue?
    11,828
    Darren...first ye gotta catch the rabbit...........
    Constantine, MI
    7,890
    Do the waskely wabbits adhere better?
    www.wrworkshop.com
    Apr 2009
    Outside the beltway
    5,250
    I order the glue on line, You will need a double broiler or a crock pot and a mason jar. I use about 1" of the rabbit skin glue buttons to 2" of water, let it sit over night and then in the morning add a touch of water and place in crock pot , do not boil just get very hot. Most of the time if your doing small veneer you can use blue 3M type to hold down till dry. 1 pound will last along time. You turn it off when your done and just turn on when you need glue again.
    Oct 2008
    1,357
    What's the difference between this and hide glue?
    Aloha,
    Apr 2009
    Outside the beltway
    5,250
    I'm not sure what is in Hyde glue. I used it for a while and liked it but I found the I can strengthen up the rabbit skin glue by adding to the pot when I need a stronger bond. plus it is a lot less money.
    Interesting about the epoxy sticks Dave. I use that stuff frequently with my furniture repair business, I've never had a problem with it not forming a rock solid grip all on its own. You have to follow the directions and really press it into the exposed grain of the wood. I myself have found that when there is glue in the area that the filler is going, it doesnt hold as well so I've actually had to remove glue to make a better fit w/ the epoxy. To each their own I guess
    Go ahead and run clown, with those big floppy shoes, you won't get far.
    11,828
    When my father, who was a professional woodworker, died and I cleaned out his things, I found a bunch very old Fine Woodworking magazines. One that I saved for a while had an article on the use of hide glue. (isn't Hyde a brand name?)
    The article said that furniture which had been made with this was still in great condition many years afterwards.
    My father had a hot pot he used. Smelly stuff but probably was best available at the time.
    30,008
    I'd never hear of rabbit skin glue, but it does appear to be a type of hide glue, but it's also used as sizing (primer) for oil paint artists:
    http://en.wikipedia.org/wiki/Animal_glue
    http://en.wikipedia.org/wiki/Rabbit-skin_glue
    Hide glue has been used a lot by luthiers. It makes a strong, yet repairable (and un-doable) joint.
  2. Glue
    Last Post: 01-17-2013, 12:48 AM
  3. Which glue?
    By Rex Bloem in forum General Woodworking Q&A
    Last Post: 07-06-2011, 01:29 PM
  4. CA glue
    By Shawn Lakes in forum General Woodturning Q&A
    Last Post: 05-19-2007, 12:57 PM
  5. OK, now the glue?
    By Chuck Hanger in forum Turning Tool Questions and Show & Tell
    Last Post: 04-27-2007, 03:12 AM
