Results 1 to 4 of 4
Thread: Captive Hollowing rigs
    Kaneohe HI.
    70
    For those that have made there own Steel snake or similar rigs, what type of cutter bars works best? Is the straight bar much more versitile than the Swan neck type. Your comments and experiences would help when I fabricate my 5/8" shaft bars. Currently I'm using 1/2" bars,straight and swan neck with a adjustable bit holders.
    Jul 2007
    DSM, IA
    5,719
    John I would copy what you already have in 1/2" when you fabricate your 5/8 stock if possible. Gives you more options when your turning.
    My Website
    Kaneohe HI.
    70
    Hollowing bars
    Jeff, the only draw back is bending the 5/8" bar. I had a hard time on the 1/2". Any suggestions as to bending it? Maybe do a 45 deg. only?
    Jul 2007
    DSM, IA
    5,719
    All you need is a vise, mapp gas (or propane, just takes longer) and a pipe to slide the bar into to use as a cheater to bend it. Or I've also seen it done by sticking the bar into a grill loaded with charcoal until its red hot and then bend it...again just takes longer.
    Vaughn typed up a great tutorial on his bars as well >>Click Here<<
    My Website
  1. Captive Hollowing Tool Bar ?
    Last Post: 11-18-2012, 02:48 AM
  2. Captive ring goblet
    By Drew Watson in forum Lathe Project Showcase
    Last Post: 12-01-2010, 08:40 PM
  3. D handle captive hollowing rigs?
    By M Toupin in forum Turning Tool Questions and Show & Tell
    Last Post: 06-30-2008, 04:47 PM
  4. Replies: 0
    Last Post: 03-27-2008, 01:49 AM
  5. Hollow Form rigs
    By Doug Jones in forum Turning Tool Questions and Show & Tell
    Last Post: 03-09-2007, 09:02 PM
