Results 1 to 7 of 7
Thread: Wedged tenons
    Herndon VA
    180
    Wedged tenons
    I'm working on my workbench and it calls for wedged tenons for the legs and top trestles as well as the stretchers. I was doing a little reading about wedged tenons. Generally they call for the mortise to be undercut on the ends on onside to create a an angled mortise. This will allow the wedge to create a mechanical joint by flaring out the tenon to fill the mortise. My question is for hard maple I was thinking about making the undercut on the mortise about a 16th on both ends. Is that enough? This is my first attempt at wedged tenons.
    Thanks
    Steve Clardy Guest
    How wide will your wedge be? 1"? or?
    Herndon VA
    180
    Steve - the tenons are 1" x 2 1/2" and 1 1/2" x 3" wide. I was going to cut the wedges in the tenons 1/4" from the edge and make them 1/8" wide.
    Steve Clardy Guest
    I'd go an 1/8 or so taper
    mike, if you cut the tennons 1/4" away from the edge you`ll need to drill a hole at the end of your cut so the wedge isn`t trying to flex a full 1/4" of maple(splitting is a concern) here`s a really bad drawing....
    Herndon VA
    180
    Tod - That was what I was planning on doing.
    Steve - the 1/8" taper is for the mortise? Instead of my 16th?
    Steve Clardy Guest
    Yes. Taper for mortise and wedge
  1. Dowels and Tenons
    By mike marvel in forum General Woodworking Q&A
    Last Post: 02-08-2014, 03:40 AM
  2. How to cut Tenons
    Last Post: 11-28-2010, 10:57 PM
  3. Quick and Easy Mortises and Tenons?
    Last Post: 06-26-2010, 07:29 PM
  4. Trimming Tenons
    By John Daugherty in forum Neander Woodworking Q&A
    Last Post: 02-02-2010, 02:09 PM
  5. Loose tenons
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 05-04-2009, 01:20 AM
