Results 1 to 5 of 5
Thread: Loose tenons
    Apr 2008
    We now divide our time between southwest Florida and southwest Vermont.
    137
    Loose tenons
    I just ordered the Mortise Pal and a Milwaukee 5615 plunge router to use with it. I recall some discussion of making loose tenon stock in advance and cutting pieces as needed. I assume you rip rectangular pieces with a cross section that reflects the length and width of the mortise, and trim the edges round on the router table. Is there a better or easier way?
    Tony
    The optimist says the glass is half full.
    The pessimist says it's half empty.
    I say the glass is twice as big as it needs to be.
    Jun 2007
    Stafford, VA
    51
    I don't have an answer for you as I've never done it, but I am interested to know how you like the Mortise Pal once you've worked with it awhile.
    Frank
    The only thing required for evil to triumph is for good men to do nothing...www.jbs.org
    Dec 2008
    falcon heights, minnesota
    5,609
    i've always made my tenons right along with the mortises. but then again, i've never used a loose tenon. i figure thats why god made biscuit joiners...
    benedictione omnes bene
    www.burroviejowoodworking.com
    Floydada, Tx
    1,941
    either round over the tennons or square up the mortise. The end do not have to be perfect, as long as the main part is tigth.
    I mill 2 - 3 foot stock to thickness and then rip to width on the tablesaw. I then round the four long edges with the appropriate radius bit in the router table. I keep a bunch of prepared 'sticks' with the size written on the end in felt pen where I store my dowels. I cut them to length when needed.
  1. Dowels and Tenons
    By mike marvel in forum General Woodworking Q&A
    Last Post: 02-08-2014, 03:40 AM
  2. How to cut Tenons
    Last Post: 11-28-2010, 10:57 PM
  3. Quick and Easy Mortises and Tenons?
    Last Post: 06-26-2010, 07:29 PM
  4. Trimming Tenons
    By John Daugherty in forum Neander Woodworking Q&A
    Last Post: 02-02-2010, 02:09 PM
  5. Wedged tenons
    By Mike Gabbay in forum General Woodworking Q&A
    Last Post: 01-06-2007, 03:25 PM
