Results 1 to 10 of 23
Thread: Going Big
    Going Big
    I got a chance last night to try turning some of my recent elm haul, and I figured some of you guys might like to see some pics of the journey.
    Of the two biggest blanks I got out of that wood, one had some cracks already started, so I figured I'd turn it now instead of trying to seal it and hoping the cracking would stop. The blank was about 24" to 25" across at the widest. I had to get LOML's help to mount it on the lathe. I could lift it into place (barely), but I needed her to turn the handwheel to get the faceplate threaded onto the spindle. I'm guessing the blank was in the neighborhood of 90 to 100 pounds. Definitely the biggest diameter and heaviest piece I've turned yet.
Name:	Elm Crotch 1 Progress - 01 800.jpg
    Here's a shot showing where I had the remote switch while roughing. (The shop's a mess since I had to rearrange things to turn at the end of the lathe.)
Name:	Elm Crotch 1 Progress - 02 800.jpg
    Getting started, using my Monster Oland-style tool and a 1/4" cobalt bit. The 24" handle is filled with lead shot, so it's pretty hefty.
Name:	Elm Crotch 1 Progress - 03 800.jpg
    Getting more round...
Name:	Elm Crotch 1 Progress - 04 800.jpg
    Starting to look like a bowl. By now, I had switched to the Ci1...
Name:	Elm Crotch 1 Progress - 05 800.jpg
    After turning the blank around and facing it a bit, it was clear that cracking might be an issue...
Name:	Elm Crotch 1 Progress - 06 800.jpg
    Popped a core out of the blank, but lost a chunk of the edge along the way. (That spot was real punky, and probably would have needed to be turned away anyway.)
Name:	Elm Crotch 1 Progress - 07 800.jpg
    More in the next post...
    Inside of the big bowl, shaping up...
Name:	Elm Crotch 1 Progress - 08 800.jpg
    Here's another look at the missing chunk. You can see the punky area that's going to be turned away...
Name:	Elm Crotch 1 Progress - 09 800.jpg
    Here's the outside of the "small" core after a bit of cleanup. I turned this one over the regular bed, just since there's a bit less vibration when I'm not using the tool rest extension...
Name:	Elm Crotch 1 Progress - 10 800.jpg
    The smaller bowl will be relatively shallow...
Name:	Elm Crotch 1 Progress - 11 800.jpg
    And the cracks are back to haunt me...
Name:	Elm Crotch 1 Progress - 12 800.jpg
    But it survived so far. I'll be trying to fill the crack with epoxy and some type of filler material once the wood dries.
Name:	Elm Crotch 1 Progress - 13 800.jpg
    And the nights' work...
Name:	Elm Crotch 1 Progress - 14 800.jpg
    Both bowls are sitting an a trash bag with wet shavings for now, but later today I'm going to try to rig up a DNA soak for them. Before I do that, I'm going to remount the big one and turn down the notch in the rim.
    I hope you enjoyed the ride...
    Nov 2008
    Tampa & NC
    432
    Going big
    WOW,awesome,can't wait to see the finished piece
    May 2009
    sydney australia
    149
    Great color and shape, but I see you have a few imperfections to deal with. It will be interesting to see how they come at the finish.
    13,468
    his-n-her popcorn bowls?
    15,809
    How big are them doggies you got
    Sure is pretty wood, that looks so very much like the Japanese Elm that I get all the time. Was it stinky when you turned it?
    You need to rig a skyhook over your lathe
    Floydada, Tx
    1,941
    Very nice. Timew for a chain hoist.
    Inside the Beltway
    2,666
    what they said! Chain hoist, winch, something!
    Looks like lots of fun, though...
    Bill
    Sep 2007
    Plainwell, Michigan
    4,857
    [QUOTE=Bill Lantry;159788]what they said! Chain hoist, winch, something!
    Yes get something Vaughn, don't you already have back issues Please protect yourself Oh, that is one big bowl, nice work
