Results 1 to 10 of 14
Thread: Tennon issues and up for trade small tools
    Palm Springs, Ca
    1,169
    Below are two bowls that i broke the tennons on today.....
    Pic-1) yellow colored bowl - some type of pine or DF, using a faceplate turned the tennon and rough shape outside....then changed it around and put the tennon into my supernova with spigot jaws and turned the outside with no problem....started to hollow and "snap" then tennon tore off.....using the glue gun in the picture below (allowing 30min heat up) i reattached the tennon on this one and will let it sit overnight and try to turn again...PS this wood is very wet still...........
    Pic-2) Reattached the tennon and would not hold so i used a small square block that will fit into the jaws of the supernova - using the glue gun in the pic i attached it and will try again tomm. This wood is very very dry....
    I have tried Gorilla Glue and cynoacalate both and neither would hold on the above.........so im trying the glue gun to see if it works any better.
    On the dry not sure why it wont hold but the wet may be that the water content migrates back rapidly and just wont hold the bond......
    i did sucessfully turn 4 others today without any problem but they were different types of wood
    Lastly---------i had some small tools (all are stainless steel) that i got from a guy that i bought my buffing machine from that did alot of miniature work.....i do not need them so i have them up for trade.....posted on the classified section and thought i would add a note here with pics...that if anyone wants to trade for a good blank of wood i am willing..........thanks Dan
    Attached Thumbnails Attached Thumbnails P1010047 (600 x 450).jpg   P1010048 (600 x 450).jpg   Glue Gun.jpg   Small Tools - 1.jpg   Small Tools - 2.jpg
    12,256
    Dan for the newbie could you add a bit more to how this happened. I know it sounds stupid to ask but was it a catch or were you being very agressive or what. Just so I know what to watch out for in future. Were the tennons big enough in relation to bowl size? In the picture they seem small to me but I am a overkill kind of guy. I am looking to feed off your experience.
    Thanks.
    Palm Springs, Ca
    1,169
    Thanks Rob..........below are a pic of the jaws and chuck......they max out at 2" ............i would not say the cuts are aggressive and i even tried very light cuts on the first one because i knew the wood was very wet....thanks see below
    Oct 2008
    1,357
    Nice collection of hemostats! Back in the late 60's and 70's they made great roach clips DAMHIKT
    Aloha,
    Palm Springs, Ca
    1,169
    LMAO...........
    Goodland, Kansas
    4,834
    Dan those are some pretty small tenons for the bowl size. I try to make my tenon's at least 1/3 the diameter of the bowl. The smallest tenon I would use would be 2 1/2" on a 8" or smaller bowl. On a 12" and up bowl I use a 4" tenon. I just don't think you have enough wood there to hold by the looks of the pictures.
    Bernie W.
    Tellico Plains, Tennessee
    4,352
    Quote Originally Posted by Bernie Weishapl View Post
    My thoughts also, and pine is really soft and will tear easily anyway... I've used a few pine waste blocks and usually eventually will tear them in half where the jaws of the chuck make an indent into the wood.
    Also on your glue, I'm not sure that the glue gun has sufficient strength to handle the torque you put on it... a good wood glue will create a bond that will out last the wood around it... JMHO...
    Chuck
    Tellico Plains, TN
    Palm Springs, Ca
    1,169
    Bernie - Chuck
    Bernie.........ya im going to look into changing to the powergrip jaws for my super nova they will go to 3 7/16, bowl jaw set are all different sizes but the larger 5" jaws are from 4 3/16-5", the 4" bow jaws are 3 1/16-3 3/4 but im going to call them first to see that i get the best jaws for the supernova i can........Any thoughts........i have a Jet 1642, 16" swing.........
    Chuck........what kind of glue do you use to hold your blocks on ??
    i have tried CA,Hot glue, Titebond III, gorilla glue...........anything better you or anybody using ??
    4,352
    I usually use a Titebond type of glue.. I'm not particular to a brand.. usually whatever is inexpensive and available at whatever store I happen to be in when I pick it up... I usually go to Lowe's, but have also bought at Wally-world and at my local no-name hardware store.
    Just make sure you have good clean flat surfaces and I clamp overnight before trying to turn.
    On the chuck jaws, I have two of the Barracuda's from PSI that I use.. the largest tenon I can clamp on is about 2 3/4.. I need to pick up another set of jaws - I think PSI calls them Nr. 3 that will allow me a larger tenon... especially now that I'm turning larger bowls.
    Chuck
    Tellico Plains, TN
    Goodland, Kansas
    4,834
    On my Vicmarc or actually the $99 Grizzly Vic clone I have the 4" jaws. Here are the ones I use. They go from 3 5/16" to 4 3/4".
    http://www.packardwoodworks.com/Merc...fourjaw-vic100
    Bernie W.
  1. Snap Tennon
    Last Post: 06-05-2010, 04:23 AM
  2. Mini Tools for trade
    By Dan Mosley in forum Old Ads
    Last Post: 05-05-2009, 03:10 AM
  3. Tennon Question again
    Last Post: 02-09-2009, 02:18 AM
  4. Day off and Tennon Problems
    Last Post: 01-06-2009, 06:52 PM
  5. Dovetail Mortice & Tennon
    Last Post: 07-07-2008, 01:14 AM
