if anyone is still following this build, I received the hinges, so I fitted the doors today, now I will just rub on some formsbys and poly mix.
2 of each onthe unit, formsbys and poly mix, and I think its done. As you can see in the close ups, I tried to let it dry outside today, covered under tent, but I got alot of dust on it when I attempted to fit doors.
Ill wipe it down again before it dries.
When setting the doors, I wanted to match the gaps on both sides, so I saw how much gap there was with hinges on, and tried eagle eye to match it up other side. I used pennies to set top and bottom heights. ONce the top is on, and the inside is dark, I dont think anyone will notice any of that.I have nice darkened/antique knobs, for pulls, but I will keep playing with mahogany and see if I can come up with a knob.
I made one set yesterday, my wife said toss it, so I did.
since I was wiping this morning, I wiped on a coat of Messemers deck treatment oil on my outdoor ipe furniture. First I lightly sanded the arms and seat, then I sprayed it off with the garden hose, dried it in sun, then wiped on the oil. It snaps the color right back to life. 3 times a year.
Im struggling out in the heat today, didnt realize when I was told to avoid heat while on Mestinon, someone must have meant it.
Ill rub some coats today, and I want to build a small wood holder for my Ashley Iles chisels, figured they deserve a rack instead of being tossed around with the tools in the drawer.
