Results 1 to 5 of 5
Thread: First inlay bowl
    Aug 2008
    Reno, Nv
    3,632
    First inlay bowl
    A few things went wrong with this when I was trying to work the base. There are a couple of good knots in the base that did a little catch thing and shot it across the bench. The rim and inlay was re-worked and then the bottom. Only one coat of Wipe-on Poly so far.
    The actual inlay process isn't that bad. Did a recess 1/4" below the rim for whatever reason. Silver maple 8x2.5. Hope it passes and thanks.
    17,470
    yup jim i think it needs to be passed on to me the inlay looks fine to me.. do you use epoxy to hold the turguose in suspension to fill your rercess?
    Red Deer, Alberta, Canada
    618
    That's a good looking bowl. I'd also like to know your method of holding the turquoise in place. Very nicely done.
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Goodland, Kansas
    4,834
    Great looking bowl Jim. The inlay really sets it off.
    Bernie W.
    Dec 2008
    falcon heights, minnesota
    5,605
    very good looking bowl there jim!
    yer gittin a lil tu closs tu tem spinny guyz larry, nexs ting ya now, yu'll b spinninnin too...
    benedictione omnes bene
    www.burroviejowoodworking.com
  1. Inlay help
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 04-08-2009, 08:32 AM
  2. inlay kit
    By Eduard Nemirovsky in forum General Woodworking Q&A
    Last Post: 07-15-2008, 10:21 PM
  3. Ironwood bowl w/inlay
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 02-04-2008, 05:54 PM
  4. Frued Inlay Set
    By Keith Starosta in forum General Woodworking Q&A
    Last Post: 12-28-2007, 04:16 PM
  5. 1st Inlay
    By Ed Nelson in forum Flatwork Project Showcase
    Last Post: 08-14-2007, 01:10 PM
