Results 1 to 4 of 4
Thread: Finished a couple projects
    Palm Springs, Ca
    1,166
    Had a few hours today of free time and decided to finish a couple bowls and play around.......First pic below is a pc of burl of some type that i had finished turned in one session and put 4 coats of antique oil on, white diamond buff and wax buff. The pc was very big but due to cracks i had to cut it down to this size and turn it. Sure wish it was a big pc i really liked the finish when it was done.
    Pic 2,3,4 were a large pc of some type of pine i think.......finished turned it and sprayed it down lightly with soapy water and put it in a brown bag with the top open and taped across the top. Left to dry for a couple weeks (actually forgot about it until today) opened it up and noticed a crack (small in the bottom) so i enhanced the crack and filled it with powder malichite. On the outside i noticed a crack were the pith was but it didnt crack on the inside as i had put some ca glue drops on it and let it soak in but forgot to do it to the outside ------- so i enhanced the crack there to with my foredom tool and filled it also with malichite powder.........So in the future im thinking that if i saturate the pith well with ca glue and brown bag them i may not get the cracks and can use the pith in the turnings........total thickness is approx 1/8 top and bottom.........any thoughts ??
    Anybody got any good finishing ideas for light woods like this....pine-Dougfur etc --- besides the blonde look that works well ??
    Attached Thumbnails Attached Thumbnails Burl (600 x 450).jpg   Big Pine 2 (600 x 450).jpg   big pine 3 (600 x 450).jpg   big Pine (600 x 450).jpg
    Red Deer, Alberta, Canada
    618
    That burl is one beautiful piece of wood!
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Hi Dan having the pith in your piece will always cause issues- soaking it in ca before bagging will help but wont solve it- i somtimes drill the pith out let them dry then plug it, but if i can I will cut my blanks to avoid the pith.
    a nice finish for lighter woods is lemon oil or organoil oil both give a subtle satin finish which i like on light woods.
    Palm Springs, Ca
    1,166
    Thank you for the reply on the finish idea.........and agree on the pith but always playing around to see if i can dry one and ensure it does not crack. this one only cracked on the outside where the ca was not applied. Reason is i forgot and possibly it may not have cracked.
    The interesting thing it did do was to bluge out on the outside and on the inside made a slight crater........ill post pictures when finished and thanks again
  1. A Couple of Projects
    By Bill Arnold in forum Computer-Aided Equipment Project Showcase
    Last Post: 07-25-2015, 03:12 PM
  2. A couple of new projects
    By Mike Mathieu in forum Flatwork Project Showcase
    Last Post: 06-04-2014, 01:42 AM
  3. A Couple Projects
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 10-11-2012, 11:42 PM
  4. Couple of projects done.
    By Rex Bloem in forum Flatwork Project Showcase
    Last Post: 07-05-2010, 03:21 PM
  5. A couple of finished projects
    By Jay Knepper in forum Flatwork Project Showcase
    Last Post: 12-13-2006, 12:03 PM
