Results 1 to 4 of 4
Thread: breif how to goblet-again!!
    this is how i do my goblets - everyone has there own way- this isnt meant to be "the only way" or "you must do it this way" just a breif guide, as always find which way/tools work for you.
    I started with a blank of light coloured Elm 9" long by 2 1/2" diameter
    I marked out the bowl section and the base using the golden rule (1/3rd to 2/3 rds) as a guide
    heres the bowl roughed out
    a bit more defined- at this stage i stop on the outside and hollow out the inside
    I use a spindle gouge on its side to hollow out- this bowl is about 3" deep- if your learning i would advise you to not go any deeper than 2" until you get the hang of end grain hollowing.
    here it is hollowed out- before sanding
    I sand this section now as you cant come back to it once the stem is started- here it is sanded and oiled
    I start to shape the stem
    here the stem and base are complete
    and here it is after being sanded and oiled
    and here it is done- i dont revesrse turn goblets - I part them of then clean up the base by hand
    I really like this design- i might make several similar to play around a bit more with the proportions though.
    I hope this is of some help- any questions just ask, if you dont want to ask here drop me a pm
    30,014
    Excellent stuff, George. Both the tutorial and the finished product look great. I dropped a copy of your post over in the Tips and Tuts section.
    Red Deer, Alberta, Canada
    618
    Thanks again, George. Another great tutorial.
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Goodland, Kansas
    4,834
    Thanks George.
    Bernie W.
  1. My first goblet
    By gary doby in forum Lathe Project Showcase
    Last Post: 03-14-2010, 12:40 PM
  2. breif how to box-again!!
    By George Watkins in forum Lathe Project Showcase
    Last Post: 05-07-2009, 04:03 PM
  3. Goblet
    By Shawn Lakes in forum Lathe Project Showcase
    Last Post: 08-21-2007, 06:06 PM
  4. Another Goblet
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 06-23-2007, 05:32 PM
  5. Goblet
    Last Post: 05-31-2007, 07:45 AM
