Results 1 to 10 of 11
Thread: Fixing "Whoops" Holes
    Now we have all done it, I know I've done it more than most, but sometimes you drill a hole in the wrong spot, or that drill bit is too long.... etc, etc.....
    This is something that I learned along the way, heck, I might have even seen it here the first time, I dunno Or online, or a magazine etc.
    I got a couple of unsightly holes, these are from when I was trying to use the pocket hole jig to join the two pieces of wood to make my legs, I drilled the wrong piece
    This is a 10mm bradpoint bit, the hole is a LOT bigger than the point on the bit, so it will NOT center and will just make an even bigger mess....... DAMHIKT
    I take a block of wood, I mark the place I want the guide hole, with the pencil line first, that way, after I'm done drilling, I will know the lines are the center of the guide hole. In this case I made the hole on the piece of MDF the same distance from the edge of the side of leg as the hole I want to plug, just easier that way.
    I line up the guide block, and drill the hole, about 3/8" deep is fine, keep the drill nice and steady and level.
    I did two, notice that the holes to be plugged are not exactly in the center of the new hole? Don't matter at all.
    Put some glue on some tapered plugs and tap them into place, try to leave the plugs just a touch proud.
    Once the glue is dry, shave the plugs off, I like a block plane for this, but a sharp chisel works too, a light sanding and you are done, easy.
    Like I said, this may be an old trick to a lot of guys, but I was doing it on the back bench, so I thought I'd take some pics and share.
    As always comments, critiques welcome
    Jul 2007
    DSM, IA
    5,719
    Thanks Stu! I have a couple "OOPs items" that this will work great for.
    My Website
    5,172
    BTDT!
    I also cut my own plugs trying to match color and grain, and then align the grain when gluing them in. I know this is "shop furniture" but it is also a good place to practice!
    When I bought my plug cutter, I went through all my 3/8" brad points until one cut a hole that exactly matched the plug my cutter produced. They are now stored together!
    Just a thought.
    Alexandria, Virginia
    1,071
    Very nice Stuart.
    I use a slightly different approach:
    Step 1. Buy new board.
    Step 2. Re-drill holes.
    Step 3. Repeat.
    This works for "accidental" dog holes too . . .
    BTDT!
    Just a thought.
    Carol, I had a LV tapered plug cutter, but for the life of me I cannot find the darn thing, I guess it is time to buy another one....... so I can then find the first one
    5,321
    ...I had a LV tapered plug cutter, but for the life of me I cannot find the darn thing...
    I have a set of those, and they come in very handy.
    Right now, I'm refinishing our kitchen cabinets, and replacing the hardware. The new handles have a completely different bolt pattern than the old, so I'm using a variation of your technique to patch/plug the old holes. I've cut plugs out of face-grain oak, and then installing them, paying careful attention to grain matching, with hide glue. Once sanded and stained, thay're nearly invisible.
    Twenty-one doors and drawers done so gar - 'only' 17 more to go!
    Per-zakerly the way I repaired gaping holes in a Paneled wall, Seems the "fixit man" dug out a large hole to hang a small reading lamp using Big Toggle bolts. Lamp went away but the hole stayed.
    I made a similar jig 5/8" and double sided taped it to the wall Forstner bit (I used) and drilled only as deep as the paneling (plaster board behind the paneling, Used a Plug cutter and a scrap of the paneling from behind the baseboard, oriented the grain and glued in, almost invisible patch (or should we call it a Dutchman?)
    That is a great way to Un-Oops or to repair someone else's Oops. Thanks for the posting.
    Good job on the paneling Bill, that would be a whole lot harder than regular wood
    Inside the Beltway
    2,666
    Quote Originally Posted by Frank Townend View Post
    Very nice Stuart.
    Yeah, me too! This is why the angels invented Bondo!
    And it's not just for shop furniture anymore! You should see my pantry shelves...
    Bill
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  3. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  4. Replies: 5
    Last Post: 12-10-2009, 04:45 AM
  5. "Cording" the "Cordless" drill
    Last Post: 10-01-2008, 03:52 AM
