Results 1 to 2 of 2
Thread: raised panel tutorial, Table saw
    Dec 2008
    falcon heights, minnesota
    5,605
    raised panel cutting on ts with jig part 1
    the first 2 pics are of the jig, the third is the board to be cut, the fourth is how the jig rides on the rip fence, the fifth is the board clamped in place, and the sixth is the blade raised and tilted to the desired angle. in this case, 14 degrees.
    Attached Thumbnails Attached Thumbnails IMG_0579.JPG   IMG_0578.JPG   IMG_0577.JPG   IMG_0576.JPG   IMG_0575.JPG
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,605
    raised panel cutting on ts with jig part 2
    the first four pics are of the first 4 cuts, pic 5 is after returning the blade to 90 degrees (that's up and down larry ) and lowering the blade to about a little more than 1/4" or so, and the sixth pic is of the finished panel.
    i hope this helps you allen. it took longer to take the pics than to cut the panel.
    Attached Thumbnails Attached Thumbnails IMG_0581.JPG   IMG_0582.JPG   IMG_0583.JPG   IMG_0584.JPG   IMG_0585.JPG
  1. Raised Panel Doors in SketchUp
    Last Post: 12-31-2012, 03:42 AM
  2. Raised panel closeout
    Last Post: 03-22-2012, 01:45 AM
  3. Raised Panel resized?
    Last Post: 01-16-2011, 04:27 PM
  4. Replies: 7
    Last Post: 09-12-2009, 02:42 PM
  5. Raised Panel Door
    By Sean Wright in forum Flatwork Project Showcase
    Last Post: 03-29-2007, 12:16 PM
