Results 1 to 10 of 18
Thread: Walnut Crotch HF with Ebony Finial
    This is a piece of eBay wood I've had for a while, and I finally got around to doing something with it. I think it might be the prettiest piece of walnut I've turned, but it gave me fits trying to get a finish I was happy with. I had a few coats of Antique Oil on it and it was kind of streaky since the finish was old, but I went ahead and tried to buff it. The tripoli helped some, but then I made the mistake of buffing it with white diamond. The finish clouded up like a summer thunderstorm. I ended up sanding it all down to bare wood and starting all over, this time using some (newer) Formby's Tung Oil finish. A couple coats later, I rubbed it out by hand with Micro Mesh to 12000, then buffed with just tripoli followed by Renaissance wax. The finial and its base are ebony, with no finish, just tripoli and wax.
    It's about 9" wide and 7" tall to the top of the finial.
Name:	HF052 - 01 800.jpg
ID:	32134 Click image for larger version.
Name:	HF052 - 05 800.jpg
ID:	32138 Click image for larger version.
Name:	HF052 - 04 800.jpg
    Comments, critiques, and suggestions are always welcome -
    Cornwall, England
    392
    It's a lovely piece of wood and you've certainly done it justice. It's really hard to get the proprtions right on these things isn't it.
    One question....you say it has an ebony finial and base, can't see the base, I assume it's very small?
    Pete
    Pete, I was referring to the base of the finial. I used a pen blank for the skinny part, but needed a bigger base to cover the hole, which is about 1" in diameter. You can see the joint between the two, particularly in the second picture.
    Cornwall, England
    392
    Aah, I see.
    Pete
    Tellico Plains, Tennessee
    4,353
    Vaughn,
    That looks like it might be a Claro Walnut... it's a beautiful wood and I like the form.
    Looks great.
    Chuck
    Tellico Plains, TN
    Los Angeles, CA
    2,668
    Vaughn, that is indeed a gorgeous piece of wood. Proportion and shape is great and the finish is excellent.
    Red Deer, Alberta, Canada
    618
    Just lovely, Vaughn. Can't imagine how you could have done it any better.
    Of course, now you'll do one better just to show me. Right??
    Why has common sense
    become so uncommon?
    My Woodwork Site
    Aug 2008
    Reno, Nv
    3,632
    Nice work. Good looking piece of wood.
    Fantastic Vaughn, that is really pretty wood, and boy does that form show it off!
    As always, your pics are top drawer too!
    Lake City, Florida
    498
    Absolutely Beautiful Vaughn
    Tony, BCE '75
  1. Pet urn in walnut and ebony
    Last Post: 03-30-2012, 07:34 PM
  2. Michigan Chocolate Crotch Hollow Form - Revisited the Finial
    Last Post: 04-22-2010, 09:56 PM
  3. Spalted Pecan Hollow Form with Ebony Finial
    Last Post: 04-15-2009, 03:01 PM
  4. Walnut Crotch
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 11-23-2007, 01:06 PM
  5. Walnut Crotch NE
    Last Post: 09-01-2007, 04:07 PM
