Results 1 to 10 of 19
Thread: Crib Build (Day 1 - ?)
    Indiana
    130
    I hope to keep a journal here of the start to finish Crib build, and yes! there will be pictures. I have a camera set aside just for this so my kid can look back and say. wow dad.. your crazy. What follows is a todo list that I'll try and keep updated. It wasnt in my origonal post but I thought it would be a good idea to help keep me on track, and also let you know about where I am in the project without haveing to search through all the posts.
    To Do List: (■ Done, □ Not Done)
    □ Finish step by step plans
    □ Finish Jig designs
    ■ Finish To Do List (5/17-19/2009)
    ■ Planer Sled (5/10-14/09)
    ■ Table Saw Rip Sled (5/18-19/2009)
    ■ Two Stage DC system (5/15-17/2009)
    □ Router Table(8/22-?/2009) [In Progress]
    □ Wood Steaming Pipe
    □ 1 Slat Jig for flat ends
    □ 6 Slat Jigs for curved ends
    □ 4 Pattern Jigs for curved sections.
    ■ Test stain (5/19-20/2009)
    □ Cut and build Sides
    □ Cut and build Headboard
    □ Cut and build Footboard
    □ Cut and build Matess Platform
    □ Cut and build tottler bed converter
    □ Cut and build full size bed converter frame
    □ Touch up and stain
    □ Sleep
    Here it what it will hopefully look like.
    And who its for
    He's just so cute!
    Looking forward to watching this Chris! You have a plan, and thats the best start!
    When is your child due? First one? We just found out #3 is on the way and due around Thanksgiving time, which will get me Christmas off from work, yes!!!
    Go ahead and run clown, with those big floppy shoes, you won't get far.
    Southern Louisiana
    947
    chris,
    first off congrats on the upcomin addition. my son is the best thing that has ever happened to me. well i guess my wife runs a very close race..
    best of luck on the build. i built my son's crib and it was a very rewarding project.
    i'll be watching
    mike, congrats on #3, that is awesome.
    chris
    Bellingham
    2,449
    Quote Originally Posted by Chris Marlor View Post
    .......So all in all it was a learning experience and hopefully the differences between myself and my fathers style of doing things will work out so we can do this project in a timely manor and safely. It just so freaked me out when he was running the wedges through the table saw by hand with no fence, one handed just following the line by eye, and yes not a single one was the same and they all had a curve to them. You had to been there. When one cut was made the cutoff just jumped around from the blade hitting it until he would flick it off... by hand. I love my dad but I worry he may be losing a finger very soon, or worse with him standing right behind small pointed stick a hard kick back might do some realy bad damage.
    Sorry for venting a bit but it was just an aggravating way to start off the project. I just hope I donít have to end up taking the project back home for both our sake.
    Chris
    Chris, I think you need to control the build. Maybe I misunderstood how your father was cutting the wedges, but I think it is just a matter of time before your father seriously hurts himself.
    Bellingham
    2,449
    I recognize the sled you are building. Personally, I just use a thick piece of plywood as a bed and hot glue wedges (cut on a bandsaw) to the wood bed and the board to be planed so that the board does not rock or wobble. I take very light cuts and it seems to do the trick. But I am only running a couple boards and only occasionally as I am able in most cases to hand plane a flat enough surface on one side so it can be run though the planer.
    Sarnia, Ontario, Canada
    55
    I remember the first diaper that I changed - whoaaaaaaaaaaaaaa
    Have fun with your new baby.
    What is a "piano top sander"
    Rod
    Indiana
    130
    Well I thought I'd give an update on how things are going. First off I decided to clean up my posts because well I want to keep this thread going in a good direction vs. talking about bad stuff Second I re-did my first post a little adding a To Do list so that I can list out things I need "to do" and check them off so both you and I know where I am in the build cause sometimes I can be a little bit forgetful.
    So here is the update on the progress. So far the Planer sled, Table saw rip sled, and the two stage DC unit are done. The two stage dc works like a dream. I'm only getting a little bit of fine dust in the bag and everything else is staying in the can. We donít have a baffle in it but may add one a little later but that should be easy enough to do.
    I'll be taking pictures today when I head over, checking some odds and ends, and probably will start getting some small boards ready for doing some test stain samples. Tonight I'll update this post with the pictures from today of what is done.
    Chris
    -As Promised-
    Planer sled and table saw rip sled
    Tested out the planer sled and it works, but I need to get used to it more.
    2 stage DC
    Works 95% I think I was able to convince dad we should go ahead and try out a baffle and see how much it improves. Right now everything is sill caught in the cyclone so some stuff over time happens to still get to the bag. Over all with this and my dust mask Iím breathing free and clear.
    These are the pieces I test planed to 1/2" then cut to 6". I have 3 white and 3 green that Iíll be using for testing out stain. If I end up needing more i still got half the board left plus another thin 8 foot I can use but hopefully these will be enough to try 4 different approaches.
    Indiana
    130
    well today I did a lot of test stain samples and i just had to share it, the one me and my wife picked, mainly cause its the first time i ever put stain to wood so here it is.
    It was alot easier to do then i thought but i will admit i still need practice i might break out the rest of the 4' and 8' x 2" poplar and when it comes time to stain the peice do it on those to make sure i got the hang of it. The steps for this was 1/2 "Homestead Dry Dyes, Dark Mission Brown" and 1/2 "Homestead Dry Dyes, Medium Reddish Brown " mixed with the recomended amount of water. I put this on as 3 coats letting it dry inbetween this gave the poplar a nice uniform dark redish brown base color. Once that dryed I hit it with "Sherwin Williams Wood Classics Interior Oil Stain Classic Cherry" let it sit about 3-5 min and wiped off the excess. Finaly 3 coats of SW-WC clear satin poly
    All in all i'm happy with how it turned out.. I did speed through it because dad had me hit it with a heat gun to speed up the poly dry time but when i practice more durring the build i'll let it set the full 24 between coats. We shall see but from a color standpoint it hit the mark.
    Let me know what you think. Even if you think its the ugliest color ever.
    Dec 2008
    falcon heights, minnesota
    5,610
    looks good chris
    benedictione omnes bene
    www.burroviejowoodworking.com
    Indiana
    130
    5/20 5/24
    Well Iíve been working on the project everyday now and hopefully tomorrow will be the day to check the sides off my list. Here is a little bit of what Iíve been doing
    The area i have to work in
ID:	32805Click image for larger version.
    The parts planed to thickness cut to width and length
ID:	32803Click image for larger version.
    Working on the curved rail, man I love sketchup!
ID:	32807Click image for larger version.
    Some sanding to do on the mortis and tendons. I'm glad I saved the scrap from the planer sled rebuild.
    And where i left it today
ID:	32810Click image for larger version.
    Today was the first day i have ever used a jig saw and router. It was so fun i was almost giggling in my respirator All in all Iíve been having a blast.
    I still have some work on sanding the mortis and tendons as they are still way too tight and donít go in all the way. I'll probably make up some new sanding sticks so I can cut the inside corners a bit better. Also I read today when I got home that I should over cut the depth of the mortise about 1/16th of an inch so I may end up doing that tomorrow.
    Oh I also got my first two injury, a blood blister from pinching my finger between two boards and a swollen index finger from smacking it with a rubber mallet.
    Untill next time! thanks for reading!
    Chris
    Focusing your life on only one path does nothing but close your mind to the infinite possibilities that surround us.
    Think out side the box for the box is small, cold, dark, and doesnít have cookies.
  1. 3-in-1 Crib/Bed
    Last Post: 10-30-2012, 02:43 PM
  2. Crib (3-in-1 bed)
    By Aaron Beaver in forum Flatwork Project Showcase
    Last Post: 09-06-2010, 02:28 AM
  3. Crib build
    By Westley Rosenbaum in forum Flatwork Project Showcase
    Last Post: 01-19-2009, 07:21 PM
  4. Crib build
    By Doug Sinjem in forum Flatwork Project Showcase
    Last Post: 11-19-2007, 02:34 PM
  5. new crib
    Last Post: 06-03-2007, 02:31 PM
