Results 1 to 3 of 3
Thread: Tablesaw Alignment - Cab Mount Trunnions
    I have been meaning to add another wing to my saw ever since I moved the Bies tube and gained 10” of additional fence capacity. Well the bug hit me as several things came together that I thought would make this a worthwhile effort:
    - My cyclone and duct work are in.
    - I made an alignment tool.
    - I’m tired of stubbing my toe on the wing.
    My saw has cabinet mounted trunnions so after I broke everything down, I went ahead and pulled the table (keeping track of any shims that were in place) so I could really clean things up, adjust backlash on the wheels and all that.
Name:	22124 Alingment 000.jpg
    I like my machines level with Mother Earth so I get the machine level first. There will be some table adjustment that will kill “perfection” so I just get real close front to back, left to right and corner to corner.
Name:	22124 Alingment 001.jpg
ID:	32172 Click image for larger version.
Name:	22124 Alingment 002.jpg
    Get that blade at 90*.
Name:	22124 Alingment 003.jpg
    Grab the alignment tool of your choice.
Name:	22124 Alingment 004.jpg
    Check front to back at the same tooth area. No surprise that after manhandling the saw and changing floor location, I have some adjusting to do. A socket and a mallet are the first tools I use. I loosen 3 of the 4 bolts that hold the top and tap-tap-tap till I am dead on front to back between the blade and my chosen miter slot.
Name:	22124 Alingment 005.jpg
ID:	32176 Click image for larger version.
Name:	22124 Alingment 007.jpg
    On to more stuff . . . . .
    Tablesaw Alignment - More Stuff
    Lay that blade over to 45* and check it front to back, same tooth area. You could really pick any decent angle but 45* is important to me so I may as well get it as good as I can right there. Aligning these to points requires shimming the table. The long LV feelers are great for this and make it easy.
Name:	22124 Alingment 009.jpg
ID:	32181 Click image for larger version.
Name:	22124 Alingment 010.jpg
ID:	32182 Click image for larger version.
Name:	22124 Alingment 012.jpg
    Through some monkeying around I finally arrive at needing .015 elevation at the right front corner. Four layers of Coke can are .0155 so I’ll try that.
Name:	22124 Alingment 013.jpg
    OK, that did it for me at 45*. Return the blade to 90* and re-check/re-adjust as required to get aligned. Lay the blade back over to 45* and re-check/re-adjust as required.
    OK, I’ve got it dead-on at 90* and heeled away from the fence by .001” at 45*. I wasn’t trying for the heel-out but that was as close as I could get before I realized I could go back and forth all day and never get closer. I also didn’t want the blade heeled toward the fence at 45*.
    Oct 2008
    1,357
    Nice tut Glenn, wish you posted it before I "tuned" my machine up. Didn't think to check the table being flat to the top Something else to add to the "to do" list
    Aloha,
  1. Quick laser mount
    By Darren Wright in forum New Systems and Builds
    Last Post: 10-04-2015, 07:25 PM
  2. a question of how to mount something
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 08-10-2014, 05:55 PM
  3. TV Stand with Wall Mount
    By Timothy Wright in forum Flatwork Project Showcase
    Last Post: 10-24-2010, 01:05 PM
  4. A mount for the Man Cave
    Last Post: 06-26-2010, 03:33 PM
  5. how do you paper mount?
    Last Post: 04-06-2009, 01:06 AM
Tags for this Thread
